Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » General architecture question on performance
| General architecture question on performance [message #64008] |
Thu, 07 December 2006 15:29  |
Originally posted by: kalin.nakov.gmail.com
My application needs to handle very large models, mainly tens of
thousands objects, a number high enough so that loading and saving into
plain files and loading everything into memory is not an option. My
investigation leads me to using Teneo and JPOX resources. So far so
good, I guess I would be able to open, edit and validate my model stored
in a database and now I can do code generation with Jet based on a
Resource object (loaded EMF model). But I have the following
architecture questions before I start implementing my application to
avoid running into a dead end when scalability issues start to occur:
1) When I open a very huge model in the EMF editor, is all the model
loaded into the memory, or only the currently visible items in the EMF
editor? Is it loaded in a top-down manner by first loading the top
hierarchical levels and when I expand the tree it loads the child items
from the database?
2) When I save my document from the EMF editor, are only the changes
saved, or the whole file is written in the repository from scratch?
3) When I validate my document from the EMF editor, are all the objects
iterated and validated, or only the ones that I have changed?
4) When I use JET for code generation and use xpath queries on a EMF
model, are those queries optimized for relational database access, or
issuing a query like //MyClass will iterate all the objects in the database?
Thanks in advance,
Kalin
| Re: General architecture question on performance [message #64036 is a reply to message #64008] |
Thu, 07 December 2006 16:07   |
Kalin,
Comments below.
Kalin Nakov wrote:
> into plain files and loading everything into memory is not an option.
> My investigation leads me to using Teneo and JPOX resources. So far so
> stored in a database and now I can do code generation with Jet based
> on a Resource object (loaded EMF model). But I have the following
> editor?
Some operations will want to visit the whole model. For example, when
you execute a delete, the editor will want to find all incoming
references to clean those up. Or when you use the properties view, the
editor will want to visit all objects to offer as choices the ones that
will fit into the feature.
> items from the database?
Generally the root note is displayed and things are loaded on demand as
you visit them.
The default resource implementation loads the whole resource (but does
not follow links/proxies to other resources) and saves the whole resource.
> objects iterated and validated, or only the ones that I have changed?
All objects are visited.
> database?
No, they walk they in memory model.
> Thanks in advance,
> Kalin
| Re: General architecture question on performance [message #64131 is a reply to message #64036] |
Thu, 07 December 2006 23:36  |
Kalin,
Just to add some jpox specific info. Jpox will normally lazy load references. This means that lists
are only loaded at the moment that the first entry in the list is required (or with operations as
size()). So initially when you load the resource from the database only the top level objects should
be loaded, their children are still in the db (and not loaded).
As Ed pointed out there are several operations which force EMF to iterate over all objects. To
prevent this you can try to override EMF's iterate behavior. The lists used by Teneo
(org.eclipse.emf.teneo.jpox.elist.EListWrapper) has an isLoaded method. When you have your own
iterate logic you can for example skip lists which not have been loaded yet. This only applies if
the logic iterating through the model does not mind empty lists ofcourse.
Regarding filling the listbox choice you can try to replace this with jdo-queries to the database.
The JpoxDataStore offers methods to get all crossreferences to a certain object
(JpoxDataStore.getCrossReferencers).
gr. Martin
Ed Merks wrote:
> Kalin,
> Comments below.
> Kalin Nakov wrote:
>> editor?
> you visit them.
>> database?
>> Thanks in advance,
>> Kalin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: General architecture question on performance [message #596664 is a reply to message #64008] |
Kalin,
Comments below.
Kalin Nakov wrote:
> editor?
you visit them.
> database?
> Thanks in advance,
> Kalin
| Re: General architecture question on performance [message #596720 is a reply to message #64036] |
Kalin,
gr. Martin
Ed Merks wrote:
> Kalin,
> Comments below.
> Kalin Nakov wrote:
>> editor?
> you visit them.
>> database?
>> Thanks in advance,
>> Kalin
The Netherlands
Current Time: Wed Nov 05 09:58:04 EST 2025
Powered by FUDForum. Page generated in 0.04969 seconds
