Home » Eclipse Projects » Mylyn » Temporary TaskDeactivation while launching External Tools
Re: Temporary TaskDeactivation while launching External Tools [message #63998 is a reply to message #63975] |
Thu, 08 January 2009 08:05 |
Jörg Thönnes Messages: 229 Registered: July 2009 |
Hello Ivan,
please see this bug:
254423: Provide easy way to temporarily disable interest tracking
https://bugs.eclipse.org/bugs/show_bug.cgi?id=254423
and the check whether the suggestions from Steffen would improve your situation.
Comment and vote on this bug if you also need further improvements.
Cheers, Jörg
On 01/07/09 17:21, Ivan Pea wrote:
> Dear Sirs.
> We have some Launches defined, with the "External Tools Configuration"
> feature in Eclipse. (Mostly these are build.xml files for ant).
> These launches generate java-classes, based on a XML-file containing
> message-definitions.
> (After a Launch is finnished, Eclipse allowes to specify that the
> workspace should be refreshed.Which compiles the generated java-classes)
> The problem is, that the generated java-classes show up in the active
> Mylyn task. Even though they never have been in any Editor.
> It would be great, if the Active task, was temporarily deactivated,
> while this auto-generation & compilation takes place.
> Possibly this temporaty deactivation would best be placed in in the
> "Refresh-folder" of the "External Tools Configuration" window.
> Perhaps there are even better solutions.
> Best regards Ivan P.
Re: Temporary TaskDeactivation while launching External Tools [message #64019 is a reply to message #63975] |
Thu, 08 January 2009 08:18 |
Hello Ivan,
This bug is already resolved with regard to version control checkouts:
120499: [context] make explicitly created resources interesting, and ignore others, e.g. from CVS
checkout
https://bugs.eclipse.org/bugs/show_bug.cgi?id=120499
but I feel it does not take care about other implicit updates, e.g. by workspace refreshs.
Cheers, Jörg
> Dear Sirs.
Re: Temporary TaskDeactivation while launching External Tools [message #595660 is a reply to message #63975] |
Hello Ivan,
Cheers, Jörg
> Dear Sirs.
Re: Temporary TaskDeactivation while launching External Tools [message #595665 is a reply to message #63975] |
Hello Ivan,
checkout
Cheers, Jörg
> Dear Sirs.
Current Time: Sat Oct 19 10:57:32 GMT 2024
Powered by FUDForum. Page generated in 0.04621 seconds
