Home » Archived » M2M (model-to-model transformation) » [ATL] UML2 to UM2 transformation
[ATL] UML2 to UM2 transformation [message #63965] |
Sat, 13 October 2007 07:44 |
Originally posted by: mani2s.gmx.de
I want to transform a UML2-model (created with Topcased) to a UML2-model
in ATL.
My source-model use an own created profil vofi_profil.uml (created with
Topcased). The stereotypes are used in classes and in associations.
Now I want to exclude classes with stereotype i.e. <<Komplex>>, and
exclude associations (also compositions) with stereotype i.e. <<Needed>>.
I also need the multiplicies at the association-ends.
Do anybody know a approach to get the necessary information from the model?
Or an example (tutorial) for UML2 to UML2 transformation ?
Re: [ATL] UML2 to UM2 transformation [message #64031 is a reply to message #63965] |
Mon, 15 October 2007 10:35 |
Originally posted by: freddy.allilaire.univ-nantes.fr
I advised to use superimposition mechanism
(http://wiki.eclipse.org/ATL_Superimposition).
In a first time you need to have a transformation that made a simple
copy of a UML2 model. You can use the UML2Copy transformation made by
Dennis and available here:
http://ssel.vub.ac.be/viewcvs/viewcvs.py/UML2CaseStudies/uml 2cs-transformations/UML2Copy.atl?rev=7250&view=markup
Then, you need to write a transformation that will do the "exclusion".
For example:
module UML2Filter;
create OUT : UML2 from IN : UML2, PRO : UML2;
helper context UML2!Element def : hasStereotype(s : String) : Boolean =
if self.getAppliedStereotypes()->select(e | e.name = s)->notEmpty() then
true
else
false
endif;
rule Class {
from
s : UML2!Class (not s.hasStereotype('Komplex'))
to
t : UML2!Class(
HTH.
Freddy.
mani2s a écrit :
> Hello,
> in ATL. My source-model use an own created profil vofi_profil.uml
> (created with Topcased). The stereotypes are used in classes and in
> associations.
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [ATL] UML2 to UM2 transformation [message #64353 is a reply to message #64031] |
Fri, 19 October 2007 20:30 |
In a first time you need to have a transformation that made a simple copy
of a UML2 model. You can use the UML2Copy transformation made by Dennis
and available here:
Then, you need to write a transformation that will do the "exclusion". For
example:
module UML2Filter;
true
else
false
endif;
rule Class {
from
to
t : UML2!Class(
first of all thank you for your advise!
I tried the superimposition mechanism. Copying the model was succesful,
but the exclusion failed!
I tried the 'exclusion' without Copying the model (UML2Copy.atl) and it
wokrs!
But when I try to Copy the model and superimpose the snippet code on top,
the target model is empty!
I do it like in http://wiki.eclipse.org/ATL_Superimposition !
I work with Eclipse 3.3 and ATL 2.0.0 .
I would be pleased for any advise, thank you in advance!
Re: [ATL] UML2 to UM2 transformation [message #64376 is a reply to message #64031] |
Sat, 20 October 2007 08:50 |
Hello again,
I don't solve the problem, but I had another question!
I want to exclude all Classes with stereotype 'Komplex' plus all related
Elements, like attributes,associations so on..
Is there a function for that, or had I do that by overriding the rules
(Property, association ...).
Thank you in advance!
best regards Mani
Re: [ATL] UML2 to UM2 transformation [message #64490 is a reply to message #64376] |
Tue, 23 October 2007 09:50 |
Dennis Wagelaar Messages: 147 Registered: July 2009 |
mani2s schreef:
> Hello again,
> I don't solve the problem, but I had another question! I want to exclude
> all Classes with stereotype 'Komplex' plus all related Elements, like
> best regards Mani
With superimposition, you have to override all affected rules.
Perhaps it's more efficient in your case to adapt the definition of the
"inElements" attribute helper in UML2Copy.atl.
You cannot redefine helper attributes in a superimposed module,
unfortunately. I've tried it briefly, but it doesn't seem to work.
Perhaps we'll be able to fix this in the future ;-)
Dennis
Re: [ATL] UML2 to UM2 transformation [message #64627 is a reply to message #64468] |
Tue, 23 October 2007 21:08 |
Hello everybody,
I use atl Compiler 2006 Plug-in! At the Eclipse "Run dialog", I just had
Regular VM(with debugger) in my drop-down list, so I think both
transformations are compiled by the same compiler.
I specified one metamodel UML2: uri:http://www.eclipse.org/uml2/2.1.0/UML,
in both transformations I use this metamodel.
If I use the the Superimpose mechanism, my transformation will not go far!
/Test/transformations/Buildtime_Projekt_Einfach.atl executed in 0.282 s
(including model loading and saving).
and that's it! :-(
I superimpose the following snippet of code on top of Copy2Model.atl:
module SuperimposeEinfach; -- Module Template
create OUT : UML2 from IN : UML2;
true
else
false
endif;
helper def : inElements : Set(UML2!"ecore::EObject") =
UML2!"ecore::EObject"->allInstancesFrom('IN') ;
rule Class {
from s : UML2!"uml::Class" (
if thisModule.inElements->includes(s) and not
s.hasStereotype('Buildtime-Project-Complex') then
s->oclIsTypeOf(UML2!"uml::Class")
else false endif)
to t : UML2!"uml::Class" mapsTo s (
name <- s.name,
visibility <- s.visibility,
. ... the same like in Copy2Model.atl
ownedReception <- s.ownedReception)
At the Eclipse "Run dialog ..." I append my own created
profile.uml"(Topcased),
enabled inter-models references and continue execution after errors in Run
mode.
---> @Dennis:
your idea, to modify the inElements helper is interesting, could you give
my a snippet code?
I appreciate your help!
Best Regards,
Mani
Re: [ATL] UML2 to UM2 transformation [message #64696 is a reply to message #64627] |
Wed, 24 October 2007 07:42 |
mani2s schreef:
> Hello everybody,
> uri:http://www.eclipse.org/uml2/2.1.0/UML, in both transformations I use
> this metamodel.
Even if you're using the latest ATL, the default compiler is still set
to "atl2004" (don't know why). If you want to use the new (faster)
compiler, you have to add the following line at the top of your
transformation module:
-- @atlcompiler atl2006
> and that's it! :-(
> true
> else
> false
> endif;
> rule Class {
> else false endif)
> name <- s.name,
> . ... the same like in Copy2Model.atl .
> Run mode.
I don't have any "Copy2Model.atl". I used "UML2Copy.atl" instead. When I
superimpose your transformation, I get the following error:
SEVERE: Pattern not equal for execution environment and module in main
(getasm != load 0 @ 0)
org.eclipse.m2m.atl.engine.AtlSuperimposeModule$AtlSuperimpo seModuleException:
Pattern not equal for execution environment and module in main (getasm
!= load 0 @ 0)
org.eclipse.m2m.atl.engine.AtlSuperimposeModule.mainSanityCr ossCheck(AtlSuperimposeModule.java:103)
org.eclipse.m2m.atl.engine.AtlSuperimposeModule.adaptMain(At lSuperimposeModule.java:77)
org.eclipse.m2m.atl.engine.AtlSuperimposeModule.adaptModuleO perations(AtlSuperimposeModule.java:60)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:154)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
INFO: /uml2cs-transformations/UML2Copy.atl executed in 1.639 s
That means I need to add the "-- @atlcompiler atl2006" line to
SuperimposeEinfach.atl. After I did that, the transformation works.
> ---> @Dennis:
> give my a snippet code?
To do this, you need the latest ATL from CVS, or download ATL from the
following update site:
http://ssel.vub.ac.be/tools/atl/update/
An example transformation that superimposes a new "inElements" on top of
UML2Copy.atl can be found here:
http://ssel.vub.ac.be/viewvc/UML2CaseStudies/uml2cs-transfor mations/UML2FilteredCopy.atl?revision=7373&view=markup
It copies only instances of uml::Package. You'll probably need a more
elaborate OCL statement to exclude all stereotyped classes and all
elements directly or indirectly owned by those classes.
> Best Regards,
> Mani
You're welcome ;-)
Dennis
Re: [ATL] UML2 to UM2 transformation [message #64763 is a reply to message #64696] |
Wed, 24 October 2007 20:19 |
thanks now it works!
I had think about your idea, to overwrite the inElements() helper. I had
do that in my Superimpose.atl (superimpose on UML2Copy.atl).
true
else
false
endif;
UML2!"ecore::EObject"->allInstancesFrom('IN');
I had run it, but it takes about 30min, and after that I get errors, but
they are don't specified!
Is there an syntactic error, or maybe I cannot overwirte the helper!
Do you know a more efficient idea than mine?
best Regards,
Mani
Re: [ATL] UML2 to UM2 transformation [message #64809 is a reply to message #64763] |
Thu, 25 October 2007 15:40 |
mani2s schreef:
> Hello,
> true
> else
> false
> endif;
Hmm, then how do you know you get errors? What kind of errors are they?
Helpers that already exist in the base ATL module don't need to be
specified again. In your case, you can just use the "inElements" from
UML2Copy.atl inside your own transformation module.
Well, that would be to re-define "inElements" in your own
transformation. That requires the latest ATL from CVS, as indicated in
my previous post.
> best Regards,
> Mani
Dennis
Current Time: Sun Oct 20 16:22:56 GMT 2024
Powered by FUDForum. Page generated in 0.03084 seconds
