Home » Archived » Visual Editor (VE) » windows to linux - swt failure...
| windows to linux - swt failure... [message #63898] |
Sun, 03 October 2004 02:02  |
Originally posted by: spam.scientifik.com
I created a Java project while on a windows box, using the Visual Editor
to create a front-end to my classes. All of this was contained in a
single eclipse JDT project.
I wanted to see how feasable it'd be to take a project from one platform
to another (i.e. windows to linux)...and I'm coming up w/ problems.
My impression was; I could simply change the paths to any external jars
I'm using and pass the correct linux/gtk VM arguement, for example,
"C:\etc\etc" to "/etc/etc/etc", and it would run just as it had on Windows.
So far - no luck, here's eclipse console output I'm getting:
(<unknown>:6516): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to
allocate widget with width 8 and height -1
allocate widget with width 52 and height -1
Exception in thread "main" java.lang.NullPointerException
at snap.SnapMain.createGroup1(SnapMain.java:61)
at snap.SnapMain.createSShell(SnapMain.java:125)
at snap.SnapMain.main(SnapMain.java:109)
First of all, on the warnings, I'm not using -1 as a parameter for any of
the widgets...I've been over the code and I'm positive of that.
Here's the code where it's apparently failing:
private void createGroup1() {
group1.setLocation(new org.eclipse.swt.graphics.Point(302,40));
group1 = new Group(sShell, SWT.NONE);
group1.setText("Trials");
group1.setSize(new org.eclipse.swt.graphics.Point(200,216));
However, everything seems to be in place...no warnings or errors,
everything compiles fine.
I can run other SWT apps on linux but those were built on linux (not that
there should be any difference!)
Also, like I said, this runs on Windows flawlessly.
My classpath is fine, other projects are working in this directory.
Just in case, here is the string I'm passing to the VM in the eclipse
"Run" dialog:
-Djava.library.path=/opt/eclipse-3.1M2/plugins/org.eclipse.s wt.gtk_3.1.0/os/linux/x86
I'm sure this is correct - it is working for the aforementioned
linux-built SWT projects and I've verified more than once that this is the
correct path...
Any ideas?
Thanks!
| Re: windows to linux - swt failure... [message #63972 is a reply to message #63898] |
Sun, 03 October 2004 09:13   |
> "Run" dialog:
> correct path...
> Any ideas?
> Thanks!
No clue how this could have been generated but in your code:
The setLocation call (first line) is being made before the Group is
instantiated (second line). This is what's causing the NPE, as group1
is equal to null when setLocation is called on it. Also very strange
that this code runs OK on Windows. Move the first line below the second
and it should work.
- Jeff
| Re: windows to linux - swt failure... [message #64044 is a reply to message #63972] |
Mon, 04 October 2004 03:09  |
> > "C:etcetc" to "/etc/etc/etc", and it would run just as it had on Windows.
> > "Run" dialog:
> > correct path...
> > Any ideas?
> > Thanks!
> and it should work.
> - Jeff
I don't know *how* I missed that...
Very strange, I'm looking at it right now, it does in fact run on windows
like that!
VE created it that way, maybe a bug?
Thanks!
| Re: windows to linux - swt failure... [message #600479 is a reply to message #63898] |
> "Run" dialog:
> correct path...
> Any ideas?
> Thanks!
and it should work.
- Jeff
| Re: windows to linux - swt failure... [message #600517 is a reply to message #63972] |
> > "Run" dialog:
> > correct path...
> > Any ideas?
> > Thanks!
> and it should work.
> - Jeff
like that!
Thanks!
Current Time: Fri Oct 24 09:32:51 EDT 2025
Powered by FUDForum. Page generated in 0.03957 seconds
