Re: Making a JAR available to project from plugin? [message #64262 is a reply to message #63869] |
Sun, 07 June 2009 21:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: wim.jongman.gmail.com
Hi Jeffrey,
Do you generate the JARs or are these JARs third party Jars? Where do they
come from?
Wim
> Hi Folks,
> I'm writing my first plugin and it has a number of components. One is a
> wizard that helps set up the data. That's all working great. The second
> is a couple of packages of .class files that use the data.
> I know how to use the Project->properties to include the jar that contains
> these classes in my project, but that would involve distributing the JAR
> twice, ocen as part of the plugin for the wizard to use and ocne as a
> straight jar to be included in the project's properties.
> That seems kind of wasteful as well as kludgy. Is there a way to make the
> JAR that is in the plugin's code automatically part of a project generated
> with the plugins project wizard? If not is there some other way to
> package it with the plugin so it can be found and used by a project
> created by that project wizard?
> Thanks
> JK
FUDForum. Page generated in 0.03772 seconds
