Home » Archived » XML Schema Definition (XSD) » 2 levels of xsd:redefine
2 levels of xsd:redefine [message #63789] Mon, 26 September 2005 14:13 Go to next message
Originally posted by: abanerjee.vitria.com
Hi Ed,
With your help I was able to resolve the a single level of xsd:redefine.
However 2 levels of xsd:redefine does not work.
I am appending the sample program and the 4 schemas for your reference.
The 1st is the parent schema. It includes the 2nd schema which redefines
the 3rd which redefines the 4th.
The sample program prints out all the resolved elements of CompleType -
ClaimType. Am I missing something?
Thanks in advance,
-Anindita.
import org.eclipse.emf.ecore.resource.*;
import org.eclipse.xsd.util.*;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.URI;
import org.eclipse.xsd.*;
import java.util.*;
import java.io.File;
public class TestRedefine {
private XSDSchema schema_;
public TestRedefine() {
void checkComplexTypeForElement(XSDComplexTypeDefinition complexType) {
if (complexType.getContentType() instanceof XSDParticle ) {
XSDModelGroup modelGrp =
(XSDModelGroup)((XSDParticle)complexType.getContentType()).g etTerm();
checkModelGroupForElement(modelGrp, "");
} else
System.out.println("complexType.getContentType(): " +
complexType.getContentType().getClass().getName());
XSDElementDeclaration checkModelGroupForElement(XSDModelGroup modelGroup,
String tab) {
tab = tab + " ";
List particles = modelGroup.getParticles();
System.out.println(tab + "Size of particles is " + particles.size());
XSDElementDeclaration xsElement = null;
for (Iterator iter = particles.iterator(); iter.hasNext();) {
XSDTerm term = ((XSDParticle)iter.next()).getTerm();
if (term instanceof XSDElementDeclaration) {
System.out.println(tab + "FOUND ELEMENT: " +
((XSDElementDeclaration)term).getName());
} else if (term instanceof XSDModelGroup) {
xsElement = checkModelGroupForElement((XSDModelGroup)term, tab);
} else
System.out.println(tab + "wildcard group:" + term);
return xsElement;
XSDComplexTypeDefinition getComplexType(String memberName) {
List allTypes = schema_.getTypeDefinitions();
for (Iterator iter = allTypes.iterator(); iter.hasNext();) {
XSDTypeDefinition typedef = (XSDTypeDefinition)iter.next();
if ((typedef instanceof XSDComplexTypeDefinition) &&
typedef.getName().equals(memberName))
return (XSDComplexTypeDefinition)typedef;
return null;
XSDSchema loadSchema(String fname) throws Exception {
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",
new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
URI uri = URI.createURI(fname);
XSDResourceImpl xsdSchemaResouce = (XSDResourceImpl)
resourceSet.getResource(uri, true);
for (Iterator resources = resourceSet.getResources().iterator();
resources.hasNext(); ) {
Resource resource = (Resource)resources.next();
if (resource instanceof XSDResourceImpl) {
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
schema_ = xsdResource.getSchema();
return schema_;
return null;
try {
String fname = args[0];
File file = new File(fname);
TestRedefine sch = new TestRedefine();
sch.loadSchema(file.toURL().toString());
XSDComplexTypeDefinition claim = sch.getComplexType("ClaimType");
sch.checkComplexTypeForElement(claim);
} catch (Exception e) {
e.printStackTrace();
Schema 1:
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="ClaimType.xsd"/>
<xsd:element name="Claim" type="ClaimType"/>
</xsd:schema>
Schema 2:
<xsd:redefine schemaLocation="two/ClaimType.xsd">
<xsd:complexType name="ClaimType">
<xsd:complexContent>
<xsd:extension base="ClaimType">
<xsd:sequence>
<xsd:element name="NewEncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
Schema 3:
<xsd:redefine schemaLocation="../one/ClaimType.xsd">
<xsd:sequence>
<xsd:element name="EncounterFlag" type="xsd:boolean" minOccurs="0"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:redefine>
</xsd:schema>
Schema 4:
<xsd:sequence>
<xsd:element name="AccidentCountryCode" type="xsd:string" minOccurs="0"/>
<xsd:element name="AccidentDateTime" type="xsd:dateTime" minOccurs="0"/>
<xsd:element name="AccidentStateCode" type="xsd:string" minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Re: 2 levels of xsd:redefine [message #63817 is a reply to message #63789] Mon, 26 September 2005 16:33 Go to previous messageGo to next message
Anindita,
Could you provide a zip of the schemas, so that I don't have to figure
out their file names and relative locations? Or at least outline the
path names...
Anindita Banerjee wrote:
> Hi Ed,
> xsd:redefine. However 2 levels of xsd:redefine does not work.
> reference. The 1st is the parent schema. It includes the 2nd schema
> which redefines the 3rd which redefines the 4th.
> - ClaimType. Am I missing something?
> Thanks in advance,
> -Anindita.
> import java.util.*;
> } else
> modelGroup, String tab) {
> tab = tab + " ";
> tab);
> } else
> return xsElement;
> return null;
> Boolean.TRUE);
> return schema_;
> return null;
> public static void main(String[] args) {
> try {
> Schema 1:
> </xsd:schema>
> Schema 2:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 3:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 4:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Re: 2 levels of xsd:redefine [message #63840 is a reply to message #63817] Mon, 26 September 2005 16:46 Go to previous messageGo to next message
Hi Ed,
How do I attach a file to the posting?
Schema 1 and Schema 2 should be in the current directory.
Schema 3 should be a directory called "two" in the current directory.
Schema 4 should be in a directory called "one" within the current
directory.
Schema 2, 3 and 4 should all be called ClaimType.xsd.
-Anindita.
Re: 2 levels of xsd:redefine [message #63864 is a reply to message #63840] Mon, 26 September 2005 17:11 Go to previous messageGo to next message
Anindita,
Okay. I'll try to have a look tomorrow.
> Hi Ed,
> directory.
> -Anindita.
Re: 2 levels of xsd:redefine [message #63885 is a reply to message #63840] Tue, 27 September 2005 08:29 Go to previous messageGo to next message
Anindita,
This looks like yet another manifestation of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=83055. This bug and all
the problems associated with complex uses of redefine are something that
I simply don't have time to fix. You'll find that Xerces has bugs in
this area too. The whole concept of redefinition is far too loosely
defined in the spec and coming up with a consistent model for the
semantics is a challenge beyond my abilities as well as beyond my
resource capacity. Sorry. :-(
> Hi Ed,
> directory.
> -Anindita.
Re: 2 levels of xsd:redefine [message #63907 is a reply to message #63885] Tue, 27 September 2005 13:42 Go to previous messageGo to next message
Ed,
Thanks for the response. I was able to resolve element definitions with
more than 2 level of xsd:include and xsd:import. Do you know of any
bugs/limitations with multiple levels of xsd:import and xsd:include.
-Anindita.
Re: 2 levels of xsd:redefine [message #63928 is a reply to message #63907] Tue, 27 September 2005 13:47 Go to previous message
Anindita,
Other than the issue reported in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=106098 import and include
should work fine in general.
> Ed,
> with more than 2 level of xsd:include and xsd:import. Do you know of
> any bugs/limitations with multiple levels of xsd:import and xsd:include.
> -Anindita.
Re: 2 levels of xsd:redefine [message #596582 is a reply to message #63789] Mon, 26 September 2005 16:33 Go to previous message
Anindita,
path names...
> Hi Ed,
> Thanks in advance,
> -Anindita.
> import java.util.*;
> } else
> tab = tab + " ";
> tab);
> } else
> return xsElement;
> return null;
> Boolean.TRUE);
> return schema_;
> return null;
> try {
> Schema 1:
> </xsd:schema>
> Schema 2:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 3:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> </xsd:redefine>
> </xsd:schema>
> Schema 4:
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
Re: 2 levels of xsd:redefine [message #596594 is a reply to message #63817] Mon, 26 September 2005 16:46 Go to previous message
Hi Ed,
directory.
-Anindita.
Re: 2 levels of xsd:redefine [message #596601 is a reply to message #63840] Mon, 26 September 2005 17:11 Go to previous message
Anindita,
> Hi Ed,
> directory.
> -Anindita.
Re: 2 levels of xsd:redefine [message #596607 is a reply to message #63840] Tue, 27 September 2005 08:29 Go to previous message
Anindita,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=83055 This bug and all
> Hi Ed,
> directory.
> -Anindita.
Re: 2 levels of xsd:redefine [message #596620 is a reply to message #63885] Tue, 27 September 2005 13:42 Go to previous message
Ed,
-Anindita.
Re: 2 levels of xsd:redefine [message #596631 is a reply to message #63907] Tue, 27 September 2005 13:47 Go to previous message
Anindita,
> Ed,
> -Anindita.
Previous Topic:2 levels of xsd:redefine
Next Topic:errors using XSD as plugin, UnknownHostException and NPE
Current Time: Tue Nov 04 03:20:23 EST 2025
Powered by FUDForum. Page generated in 0.58027 seconds
