Home » Language IDEs » C / C++ IDE (CDT) » a debug problem: the source cound not be show as the file '' was not found
a debug problem: the source cound not be show as the file '' was not found [message #63734] Tue, 04 March 2003 10:15 Go to next message
foru is currently offline foruFriend
hi,all
When use eclipse to debug the hello.cpp,a pop window shows a message as
title.So I can't debug the program. I use the gdb 5.2.1 as the FAQ
mentioned.
Could any one can help me?
thanks
Re: a debug problem: the source cound not be show as the file '' was not found [message #63757 is a reply to message #63734] Tue, 04 March 2003 14:04 Go to previous messageGo to next message
Originally posted by: mikhailkhod.rogers.com
Did you compile your project with -g?
"Xing" <foru1971@sina.com> wrote in message
news:b41uml$fcl$1@rogue.oti.com...
> hi,all
> mentioned.
> thanks
Re: a debug problem: the source cound not be show as the file '' was not found [message #63935 is a reply to message #63757] Wed, 05 March 2003 11:17 Go to previous message
Yes,I compile the program with the -g option
Previous Topic:CDIException: No symbol table is loaded
Next Topic:What is the difference between GDB and Cygwin GDB?
Current Time: Sat Dec 21 14:23:53 GMT 2024
Powered by FUDForum. Page generated in 0.03401 seconds
