Re: How to run workflow from own code [message #63764 is a reply to message #63653] |
Mon, 06 July 2009 13:40 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
The first map (the properties) is a Map<String,String> containing all
properties you want to be replaced.
That is if you have something like
<myProp value="${foo}"/>
in your workflow file, you can pass the information what 'foo' means
using the properties map.
The other map (Map<String,Object> slotContens) allows you to put some
preinitialized information into a slot, so that components can use that
information.
This is how you solve your problem, just put an entry into the map,
mapping from a name to the actual object.
Example:
Map<String, Object> slotContents =
Collections.singletonMap("someComponent", myComponent);
can be used like this:
<expand value="templates::Template::defn_ComplexDataType FOR
somecomponent"/>
Sven
Durga Prasana Sahoo schrieb:
> Hello All
> I have a requirement to run my workflow for XPand generator, from my own
> java code.
> I found some help on:
> http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/workflow_reference.html
> It suggests to use a code snippet as follows:
> String wfFile =
> " C:/Users/Durga/workspace_TMF/org.xtext.samm.Edifice.generato r/src/workflow/EdificeGenerator.mwe ";
> Map properties = new HashMap();
> Map slotContents = new HashMap();
> new WorkflowRunner().run(wfFile ,new NullProgressMonitor(), properties,
> slotContents);
> But I don't know what the values in the HashMap should be!!
> I mean which properties of the workflow.mwe file shall I set into which
> hashmap contents.
> properties.put(??);
> slotContents.put(??);
> I need 2 also somehow pass in a component object(entity) into the
> workflow from the java code.And the workflow should then XPand a file
> for the component attributes by:
> somecomponent_object(instead of model
> file)/xml_file_representationofEntity"/>
> Wud anyone pls suggest..
> Thanks.
> Durga
FUDForum. Page generated in 0.03879 seconds
