Re: Importing Rose Model with OCL Constraints? [message #63665 is a reply to message #63641] |
Wed, 29 October 2008 17:14 |
Originally posted by: cdamus.zeligsoft.com
Hi, Axel,
This is an EMF question, so I'm replying to that newsgroup.
As far as I know, the Rose importer is not, itself, extensible by
clients (or, at least, not intended to be). I could be wrong. Ed?
I should think, though, that it wouldn't be difficult to tweak the
original to make it recognize your constraint structure. I don't know
enough about the EMF model importers, though, to give a coherent answer.
Christian
Axel Uhl wrote:
> we have a metamodel in Rose that has OCL constraints modeled as defined
> by the Unisys MOF profile as supported by the Unisys add-in for
> exporting Rose models to MOF XMI. In particular, the profile says that
> constraints on a class are modeled as nested classes with stereotype
> <<constraint>>, containing an operation whose name maps to the attribute
> "language" and whose contents on the "Semantics" tab map to the
> "expression" attribute.
> Would the EMF Rose import by any chance allow us to import these
> hundreds of constraints we have expressed this way into a set of
> constraints over an Ecore metamodel?
> Thanks and best,
> -- Axel
Re: Importing Rose Model with OCL Constraints? [message #63686 is a reply to message #63665] |
Wed, 29 October 2008 17:26 |
Ed Merks Messages: 33224 Registered: July 2009 |
Christian,
Comments below.
Christian W. Damus wrote:
> Hi, Axel,
Of course there's nothing stopping folks from extending RoseEcoreBuilder
and related classes. They're unlikely to change significantly ever
again. The JavaEcoreBuilder was changed in binary incompatible ways in
the past.
I imagine RoseEcoreBuilder could be tweaked to filter out these cases
and do something special with them. Probably it's a lot of work.
> Cheers,
> Christian
> Axel Uhl wrote:
>> defined by the Unisys MOF profile as supported by the Unisys add-in
>> for exporting Rose models to MOF XMI. In particular, the profile says
>> that constraints on a class are modeled as nested classes with
>> stereotype <<constraint>>, containing an operation whose name maps to
>> the attribute "language" and whose contents on the "Semantics" tab
>> map to the "expression" attribute.
>> Thanks and best,
>> -- Axel
Ed Merks
FUDForum. Page generated in 0.03659 seconds
