Home » Language IDEs » AspectJ » Eclipse 3.2M6
Re: Eclipse 3.2M6 [message #64062 is a reply to message #64039] |
Thu, 06 April 2006 17:52  |
Originally posted by: vranganath.sbcglobal.net
On Thu, 06 Apr 2006 15:19:10 -0500, Michael Baehr wrote:
> On Thu, 06 Apr 2006 13:30:29 -0500, Venkatesh Prasad Ranganath
> <vranganath@sbcglobal.net> wrote:
>>On Thu, 06 Apr 2006 07:56:08 +0000, Helen Hawkins wrote:
>>> Hi Venkatesh,
>>> I have Eclipse 3.2M6 with AJDT build 1.4.0.20060403091136. When I right
>>> click on both a java project and an aspectj project there is an "AspectJ
>>> Tools" entry on the context menu. The only other time this entry appears
>>> on the context menu is when a class or aspect is selected in an AspectJ
>>> project. I believe this is the expected behaviour. Your post was a little
>>> unclear - what are you selecting in the package explorer when you expect
>>> to see the "AspectJ Tools" context menu entry?
>>I'm selecting the project in the package explorer. Even more interesting is
>>that all aspectj related properties are visible when I view the properties
>>of a Java project.
>>> Also, I'm not sure I
>>> understand your reference to "_generated_src" folder.
>>AspectJ related sources are configured to be dumped into __generated_src
>>folder. Interestingly, all Java projects have this folder. I'm guessing
>>this and the above issue is because "aspectj" nature is enabled on these
>>projects. The question is how do disable it without having access to
>>"AspectJ Tools" menu?
> Do you have WTP installed? Maybe you ran into
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=130571
I believe that's it.
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: Eclipse 3.2M6 [message #593145 is a reply to message #63557] |
Wed, 05 April 2006 12:06  |
I had raised this issue earlier (bug report #131012) -- "AspectJ Tool"
menu is missing in the pop-up menu for projects in the Package Explorer in
3.2M5a. This persists in 3.2M6 as well. Can others confirm this
behavior? If confirmed, it would be great if the AJDT team could address
this as "__generated_src" folder is created for every project in the
workspace. If others are able to view the menu then any suggestions about
how to fix this anomaly?
- Venkatesh Prasad Ranganath
On Mon, 03 Apr 2006 14:53:40 +0000, Matt Chapman wrote:
> Support for Eclipse 3.2M6 is now available with the latest development
> build of AJDT (build id 1.4.0.20060403091136 or later). This is available
> via the 3.2 dev Update Site:
> http://download.eclipse.org/technology/ajdt/32/dev/update
> or as a zip file from the downloads page:
> http://www.eclipse.org/ajdt/downloads/
> Please report any bugs as usual.
> Matt.
Re: Eclipse 3.2M6 [message #593189 is a reply to message #63923] |
Thu, 06 April 2006 03:56  |
Originally posted by: hawkinsh.uk.ibm.com
Hi Venkatesh,
to see the "AspectJ Tools" context menu entry? Also, I'm not sure I
Thanks, Helen
Re: Eclipse 3.2M6 [message #593201 is a reply to message #63993] |
Thu, 06 April 2006 14:30  |
> Hi Venkatesh,
of a Java project.
Re: Eclipse 3.2M6 [message #593210 is a reply to message #64016] |
Thu, 06 April 2006 16:19  |
>> Hi Venkatesh,
>of a Java project.
Michael
Re: Eclipse 3.2M6 [message #593220 is a reply to message #64039] |
>>> Hi Venkatesh,
>>of a Java project.
Current Time: Sun Apr 27 01:34:48 EDT 2025
Powered by FUDForum. Page generated in 0.03800 seconds
