GanttChart : problem with GanttGroup [message #63518] |
Tue, 05 May 2009 13:43 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Emmanuelle Capdevielle![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=emmanuelle.capdevielle%40capgemini.com) Messages: 2 Registered: July 2009 |
Junior Member |
I'm using GanttEvents and GanttGroups into my GanttChart and I have a
little problem.
I'm using GanttChart combined to a tree, just as shown into the example.
I've got events (or groups of events) for each leaf of my tree, and I need
to have copies of these events at the node level, just like a summary.
To do that, I link my node to a GanttGroup and, when I create an Event for
one of the leaves, I copy it and add the copy into the node group.
But the copy is set following the previous events, instead of being into
the node line.
I think that this issue is due to SWT concepts but i cannot find a way to
bypass it.
I just need to add an event to an existing GanttGroup, i.e. graphically
into its line.
Can any of you help me?
Emmanuelle
Re: GanttChart : problem with GanttGroup [message #63699 is a reply to message #63518] |
Fri, 22 May 2009 16:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Emil Crumhorn![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=emil.crumhorn%40gmail.com) Messages: 169 Registered: July 2009 |
Hi Emmanuelle,
Sorry for the late reply. Could you provide me with a snippet for this? I'm
afraid I don't fully understand the description and a snippet would help me
visualize it.
Emil
"ecapdevi " <emmanuelle.capdevielle@capgemini.com> wrote in message
news:813023f695566b0feeb06b18cf9b68e1$1@www.eclipse.org...
> Hello,
> little problem.
> the node line.
> bypass it.
> into its line.
> Thanks
> Emmanuelle
Re: GanttChart : problem with GanttGroup [message #594800 is a reply to message #63518] |
Hi Emmanuelle,
visualize it.
Emil
> Hello,
> little problem.
> the node line.
> bypass it.
> into its line.
> Thanks
> Emmanuelle
FUDForum. Page generated in 0.03745 seconds
