Home » Eclipse Projects » Plugin Development Environment (PDE) » Parameterized product builds
Parameterized product builds [message #63390] Wed, 27 May 2009 09:49 Go to next message
Jesper Eskilson is currently offline Jesper EskilsonFriend
I'm trying to understand how we can move some strings out of the product
definition file (*.product). The primary things are the product name and
product versions:
<product name="Fantastic Product" version="42.4711.0">
</product>
When building this either headlessly using the PDE build scripts, or
from inside Eclipse, I would like to be able to maintain a separate
file containing the product names and versions. I tried doing
<product name="%productName" ... >
</product>
But that just made the product be called "%productName".
Is there a way to do this without resorting to automatically patching
the product definition file before building?
/Jesper
Re: Parameterized product builds [message #63415 is a reply to message #63390] Wed, 27 May 2009 10:16 Go to previous messageGo to next message
Originally posted by: mickael.istria.openwide.fr
You can externalize most of your string into the plugin.properties file,
that must be in the same folder as the .product file.
HTH
Mickael
> product versions:
> </product>
> </product>
> /Jesper
Re: Parameterized product builds [message #63437 is a reply to message #63415] Wed, 27 May 2009 10:33 Go to previous messageGo to next message
Mickael Istria wrote:
> Hello,
I did do that. The plugin.properties file contained
productName=Fantastic Product
But when launching the product, I still got "%productName" as the name.
Is there any documentation anywhere on this?
/Jesper
Re: Parameterized product builds [message #63459 is a reply to message #63437] Wed, 27 May 2009 11:34 Go to previous message
>> Hello,
>> file, that must be in the same folder as the .product file.
Ok,
Also ensure that
* You have a "Bundle-Localization: plugin" entry in your MANIFEST.MF
* plugin.properties is included in your build (build.properties must
contain plugin.properties in the bin.includes field)
Mickael
Re: Parameterized product builds [message #597900 is a reply to message #63390] Wed, 27 May 2009 10:16 Go to previous message
Mickael Istria is currently offline Mickael IstriaFriend
HTH
Mickael
> product versions:
> </product>
> </product>
> /Jesper
Re: Parameterized product builds [message #597907 is a reply to message #63415] Wed, 27 May 2009 10:33 Go to previous message
> Hello,
/Jesper
Re: Parameterized product builds [message #597915 is a reply to message #63437] Wed, 27 May 2009 11:34 Go to previous message
>> Hello,
Ok,
Also ensure that
Mickael
Previous Topic:Parameterized product builds
Next Topic:Signing jars built from site.xml?
Current Time: Sat Dec 21 14:06:55 GMT 2024
Powered by FUDForum. Page generated in 0.03389 seconds
