Home » Language IDEs » ServerTools (WTP) » Schema imports in M2 -- bug or expected behavior?
Schema imports in M2 -- bug or expected behavior? [message #63379] Fri, 07 January 2005 19:39 Go to next message
Originally posted by: not_real.not_real.com
Here's a scenario:
-Schema file A with target namespace nA:
<xsd:schema targetNamespace="nA"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns="nA"
xmlns:nB="nB">
<xsd:import namespace="nB"></xsd:import>
<xsd:element name="A">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref="nB:B"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
-Schema file B with target namespace nB:
<xsd:schema targetNamespace="nB" xmlns="nB"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:element name="B" />
</xsd:schema>
-Notice that schema file A has an import directive but an unspecified
schema location.
-The XML catalog has an entry for nB mapping it to file B.
Given the fact that the XML catalog has the entry for nB, shouldn't the
schema editor be able to resolve the reference from A to B? In M2 it
doesn't appear to...
Thanks!
Re: Schema imports in M2 -- bug or expected behavior? [message #63705 is a reply to message #63379] Mon, 10 January 2005 00:40 Go to previous message
ka wrote:
> Here's a scenario:
> xmlns:nB="nB">
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> </xsd:schema>
> schema location.
> Thanks!
Yes, in this case the schema editor should use the catalog entry. Please
open a bugzilla bug. Good catch. Thanks for your help!
Previous Topic:Volunteer for Axis Java2WSDL for M3
Next Topic:Web Services Project Problem
Current Time: Tue Nov 04 19:44:59 EST 2025
Powered by FUDForum. Page generated in 0.04919 seconds
