CDO Errors after installation [message #63319] |
Thu, 30 November 2006 16:25 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: andreas_morf.bluewin.ch
Hi all CDO-Folks
I have a problem after installing CDO/Net4j - something is wrong with the
plugin.
Accessing the Preference-Page or pressing CDO-Buttons the following errors
appear in the log:
-Could not create action delegate for id:
org.eclipse.emf.cdo.test.client.CreateResourceAction
-Plug-in org.eclipse.emf.cdo.examples.library.ui was unable to load class
org.eclipse.emf.cdo.examples.library.ui.internal.actions.Cre ateResourceAction
-Plug-in org.eclipse.net4j.examples.prov.client.ui was unable to load class
org.eclipse.net4j.examples.prov.client.ui.actions.Provisioni ngDialogAction
In the Product configuration both, the CDO and Net4j SDK's 0.7.1 appear
without any error markers
Anyone an idea?
Greets, Andreas
Re: CDO Errors after installation [message #63342 is a reply to message #63319] |
Thu, 30 November 2006 16:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andreas,
Hopefully someone has an idea because Eike is on vacation until Dec
6th.... You did eclipse.exe -clean after installing?
Andreas Morf wrote:
> Hi all CDO-Folks
> plugin.
> appear in the log:
> Anyone an idea?
> Greets, Andreas
Re: CDO Errors after installation [message #63433 is a reply to message #63342] |
Fri, 01 December 2006 09:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed,
Did it just before: same as before...
I'm wondering why eclipse is not able to load the classes even if the plugin
is loaded (as stated in the configuration-details page) and the plugin-jar
contains the according class-file?
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ekn11i$qe4$1@utils.eclipse.org...
> Andreas,
> Andreas Morf wrote:
>> Hi all CDO-Folks
>> plugin.
>> errors appear in the log:
>> class
>> Anyone an idea?
>> Greets, Andreas
Re: CDO Errors after installation [message #64635 is a reply to message #63433] |
Sat, 16 December 2006 09:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: stepper.sympedia.de
Andreas,
Sorry for the delay due to my vacation.
I believe the configuration dialog is not an indication that a plugin is
properly loaded (that is "started"). It can only indicate whether a
feature with all its plugins is properly installed. Can you please
verify that the plugin is not started in the Plugins view? This is not
possible in the runtime workbench mode!
Could you also please give me the release versions of your Eclipse and EMF?
Cheers
/Eike
Andreas Morf schrieb:
> Ed,
>> Andreas,
>> Andreas Morf wrote:
>>> Hi all CDO-Folks
>>> plugin.
>>> class
>>> Anyone an idea?
>>> Greets, Andreas
Re: CDO Errors after installation [message #596370 is a reply to message #63319] |
Thu, 30 November 2006 16:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33196 Registered: July 2009 |
Andreas,
Andreas Morf wrote:
> Hi all CDO-Folks
> plugin.
> appear in the log:
> Anyone an idea?
> Greets, Andreas
Ed Merks
Re: CDO Errors after installation [message #596970 is a reply to message #63433] |
Andreas,
Cheers
/Eike
> Ed,
>> Andreas,
>> Andreas Morf wrote:
>>> Hi all CDO-Folks
>>> plugin.
>>> class
>>> Anyone an idea?
>>> Greets, Andreas
Cheers
/Eike
http://www.esc-net.de
FUDForum. Page generated in 0.04677 seconds
