| Re: Displaying data from database with WikiText [message #65807 is a reply to message #63361] |
Mon, 23 February 2009 09:39   |
Originally posted by: tbone13.gmx.de
David Green schrieb:
> Yau wrote:
>> Hi David,
>> for displaying data from a database table using its key with a tag, say,
>> <data key="">, what's the best way to extend WikiText?
>> Thanks!
>> Yau.
> Yau, if you're using the Textile markup language then all XML tags are
> passed through to the HTML output. You could therefore do a two-pass
> rendering of the markup. The first pass would transform the markup to
> XHTML with embedded XML tags. The second pass would use the XML tags to
> process the database content.
> Alternatively you could extend a markup language such as Textile to
> include your own proprietary tags.
> Another option would be to use some other technology such as Facelets
> and JSF to render a page with logic and data, and have a custom Facelet
> tag handler or JSF tag process regions of text with the WikiText markup
> parser.
> The best approach really depends on what you're trying to do.
Hello David,
thank you for this hint, but this doesn't seem to be my problem. Inside
my IDE I created a Project and a file "test.textile". I can edit this
file and the SourceViewer is great, but the preview tab doesn't work.
Now I decided to test inside a clean new installtion. I downloaded
eclipse-SDK-3.4.1-win32 (the classic version) and added the 3 Mylyn
UpdateSites
..../e3.4
..../extras
..../incubators
to the available sites and installed the WikiText plugin.
And ... it's working fine (SourceViewer && Preview Tab)
I'll trie a --clean with my IDE tomorrow.
Best regards
Tobi
| Re: Displaying data from database with WikiText [message #65851 is a reply to message #65807] |
Mon, 23 February 2009 12:33  |
> ... snip ...
Sounds like you resolved the issue. If the problem occurs again please
file a bug.
| Re: Displaying data from database with WikiText [message #595414 is a reply to message #63315] |
Wed, 10 December 2008 15:10  |
Yau wrote:
> Hi David,
> Thanks!
> Yau.
parser.
| Re: Displaying data from database with WikiText [message #596415 is a reply to message #63361] |
> Yau wrote:
>> Hi David,
>> Thanks!
>> Yau.
> parser.
Hello David,
UpdateSites
..../e3.4
..../extras
..../incubators
Best regards
Tobi
| Re: Displaying data from database with WikiText [message #596429 is a reply to message #65807] |
> ... snip ...
file a bug.
FUDForum. Page generated in 0.06470 seconds
