Re: List Databinding [message #63718 is a reply to message #63261] |
Fri, 30 November 2007 16:43 |
Originally posted by: rherrmann.innoopract.com
--------------010508080404000804070109
I would guess that you need to provide an UpdateListStrategy
BeansObserable#observeList() call.
Attached is a snippet that shows a List widget that is bound to a model
that provides the available Locales. UpdateListStrategy, including
converters, are used there as well.
However I would rathe recommend to use a ListViewer along with an
ObservableListContentProvider.
R
Re: List Databinding [message #63766 is a reply to message #63718] |
Fri, 30 November 2007 16:52 |
Christian Messages: 31 Registered: July 2009 |
Member |
Thanks a lot Rudiger,
i've understood where I failed....i'll test your snippet asap.
Bye
Christian
Rüdiger Herrmann ha scritto:
> Cheers,
> Rüdiger
> christian wrote:
>> i've linked a List Object to an Arraylist contained in the model in this
>> way:
>> bindingContext.bindList(SWTObservables.observeItems(_listGen re),
>> BeansObservable.observeList(Realm.getDefault(), model,
>> "listGenre"), null, null);
>> _listGenre is the List object
>> in the model i have put
>> public ArrayList<String> getListGenre() {
>> return listGenre;
>> public void setListGenre(ArrayList<String> listGenre) {
>> ArrayList<String> old = listGenre;
>> this.listGenre = listGenre;
>> changeSupport.firePropertyChange("listGenre", old, listGenre);
>> In this way no items are added to the arrayList when the _listGenre is
>> filled with elements. What's wrong?
>> thanks
>> Christian
FUDForum. Page generated in 0.03112 seconds
