Home » Eclipse Projects » Remote Application Platform (RAP) » List Databinding
List Databinding [message #63261] Mon, 26 November 2007 18:11 Go to next message
i've linked a List Object to an Arraylist contained in the model in this
way:
bindingContext.bindList(SWTObservables.observeItems(_listGen re),
BeansObservable.observeList(Realm.getDefault(), model,
"listGenre"), null, null);
_listGenre is the List object
in the model i have put
public ArrayList<String> getListGenre() {
return listGenre;
public void setListGenre(ArrayList<String> listGenre) {
ArrayList<String> old = listGenre;
this.listGenre = listGenre;
changeSupport.firePropertyChange("listGenre", old, listGenre);
In this way no items are added to the arrayList when the _listGenre is
filled with elements. What's wrong?
thanks
Christian
Re: List Databinding [message #63718 is a reply to message #63261] Fri, 30 November 2007 11:43 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
--------------010508080404000804070109
I would guess that you need to provide an UpdateListStrategy
BeansObserable#observeList() call.
Attached is a snippet that shows a List widget that is bound to a model
that provides the available Locales. UpdateListStrategy, including
converters, are used there as well.
However I would rathe recommend to use a ListViewer along with an
ObservableListContentProvider.
R
Re: List Databinding [message #63766 is a reply to message #63718] Fri, 30 November 2007 11:52 Go to previous message
Thanks a lot Rudiger,
i've understood where I failed....i'll test your snippet asap.
Bye
Christian
Rüdiger Herrmann ha scritto:
> Cheers,
> Rüdiger
> christian wrote:
>> way:
>> return listGenre;
>> thanks
>> Christian
Previous Topic:Splash Screen
Next Topic:Can't set font with ColumnLabelProvider
Current Time: Fri Apr 25 00:47:52 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
