Problem running AGR in standard mode [message #63218] |
Sat, 01 April 2006 15:40 |
Originally posted by: qijia.cae.com
my test case works when running in Quick Mode.
but I run in Standard Mode, it aborts with
the error message:
IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.core.runtime.CoreException
I have Eclipse 3.1.2 and TPTP 4.1.0.1.
by the way, each time I create test case, I have
the following warning message:
Problems encountered while PDE was scanning the Target Platform
An exception stack trace is not available.
Thanks in advance,
Qijia
Re: Problem running AGR in standard mode [message #63449 is a reply to message #63426] |
Sun, 02 April 2006 05:58 |
Not immediately, Error popup after about 10 seconds.
First, "preparing and deploying" windows popup and disappear by itself.
then, loading scroll keep going until 66%, then Error comes up.
Qijia
Re: Problem running AGR in standard mode [message #63472 is a reply to message #63426] |
Sun, 02 April 2006 15:32 |
This is detail error message from error log:
Message:
problems:java.net.ConnectException: Connection refused:
connectorg.eclipse.hyades.internal.execution.core.file.Serve rNotAvailableException:
java.net.ConnectException: Connection refused: connect
Exception Stack Trace:
is there any package missing?
I just didn't install Native Logging plug-in. it's supposed not related,
right?
Qijia
Re: Problem running AGR in standard mode [message #64389 is a reply to message #63472] |
Wed, 05 April 2006 14:14 |
Originally posted by: mvjaibharatreddy.yahoo.com
Where your trying to deploy it?. localhost?
Jai
"Qijia Wang" <qijia@cae.com> wrote in message
news:95b23858fc78b09e797e596c9c917639$1@www.eclipse.org...
> Message:
> right?
> Qijia
FUDForum. Page generated in 0.03718 seconds
