Home » Eclipse Projects » Nebula » How to add context (popup) menus to the Grid column header?
How to add context (popup) menus to the Grid column header? [message #62929] Thu, 12 March 2009 14:42 Go to next message
Hi All,
I am using Nebula Grid, and wish to add context menu to the column
headers, such as:
Edit Column Definition
Remove Column
Insert Column Before...
Insert Column After...
I tried the Grid.setMenu(...) method. Obviously it pops up menu anywhere
in the control.
How could I add a popup menu only to the column header? Thank you so much!
Best Regards,
Frank Du
Re: How to add context (popup) menus to the Grid column header? [message #62931 is a reply to message #62929] Thu, 12 March 2009 16:16 Go to previous messageGo to next message
I figured it out. It is resolved by MenuDetectListener.
The issue needing attention is to convert mouse click coordinate to
relative control coordinate. Then compute the rectangle of the column
headers. Then determine is the click is inside the rectangle.
Best Regards,
Frank
Frank Du wrote:
> Hi All,
> headers, such as:
> Remove Column
> in the control.
> Best Regards,
> Frank Du
Re: How to add context (popup) menus to the Grid column header? [message #62933 is a reply to message #62931] Thu, 12 March 2009 16:41 Go to previous messageGo to next message
Hi Frank,
I was just to reply something like this. We are using MenuManager and in
the IMenuListener we are deciding which menu items we add to the menu
depdending on the current cursor location.
Tom
> Best Regards,
> Frank
> Frank Du wrote:
>> Hi All,
>> headers, such as:
>> Remove Column
>> anywhere in the control.
>> much!
>> Best Regards,
>> Frank Du
Re: How to add context (popup) menus to the Grid column header? [message #62937 is a reply to message #62933] Fri, 13 March 2009 18:06 Go to previous messageGo to next message
Hi Tom,
Thank you so much for sharing! Your method looks much more promising,
especially when we wish to display different menus on column and row
headers.
However, I have a question about determining control region. Say that we
have a Nebula Grid, with column and row headers. We set Grid's context
menu from MenuManager.
With the IMenuListener interface, how do we determine if the column or row
headers is clicked? More abstractly, how to determine which part of a
control is clicked?
Thank you so much! Have a great weekend!
Best Regards,
Frank Du
Tom Schindl wrote:
> Hi Frank,
> Tom
Re: How to add context (popup) menus to the Grid column header? [message #62943 is a reply to message #62937] Sat, 14 March 2009 07:55 Go to previous messageGo to next message
I'm using the cursor position - display.getCursor().getLocation().
Tom
Frank Du schrieb:
> Hi Tom,
> headers.
> row headers is clicked? More abstractly, how to determine which part of
> a control is clicked?
> Best Regards,
> Frank Du
> Tom Schindl wrote:
>> Hi Frank,
>> Tom
Re: How to add context (popup) menus to the Grid column header? [message #62996 is a reply to message #62943] Tue, 14 April 2009 10:56 Go to previous message
Woo hoo! I got it! Thanks so much!
Frank
> Tom
Re: How to add context (popup) menus to the Grid column header? [message #593995 is a reply to message #62929] Thu, 12 March 2009 16:16 Go to previous message
Best Regards,
Frank
Frank Du wrote:
> Hi All,
> headers, such as:
> Remove Column
> in the control.
> Best Regards,
> Frank Du
Re: How to add context (popup) menus to the Grid column header? [message #594004 is a reply to message #62931] Thu, 12 March 2009 16:41 Go to previous message
Hi Frank,
Tom
> Best Regards,
> Frank
> Frank Du wrote:
>> Hi All,
>> headers, such as:
>> Remove Column
>> much!
>> Best Regards,
>> Frank Du
Re: How to add context (popup) menus to the Grid column header? [message #594018 is a reply to message #62933] Fri, 13 March 2009 18:06 Go to previous message
Hi Tom,
headers.
control is clicked?
Best Regards,
Frank Du
Tom Schindl wrote:
> Hi Frank,
> Tom
Re: How to add context (popup) menus to the Grid column header? [message #594043 is a reply to message #62937] Sat, 14 March 2009 07:55 Go to previous message
Tom
Frank Du schrieb:
> Hi Tom,
> headers.
> Best Regards,
> Frank Du
> Tom Schindl wrote:
>> Hi Frank,
>> Tom
Re: How to add context (popup) menus to the Grid column header? [message #594345 is a reply to message #62943] Tue, 14 April 2009 10:56 Go to previous message
Frank
> Tom
Previous Topic:org.eclipse.swt.nebula.snippets - Gantchart Examples in incorrect package
Next Topic:CDateTime: Changing Icons
Current Time: Wed Apr 16 10:36:01 EDT 2025
Powered by FUDForum. Page generated in 0.04346 seconds
