Home » Eclipse Projects » Eclipse Platform » can not access help contents
can not access help contents [message #62840] |
Wed, 04 June 2003 16:36  |
I use window98 and install eclipse 2.1, but, there is yellow question mark
'?'at the front of the menu item "help content"
when I click help content in eclipse, there is error message, click on the
details: (So, I can't read online manual in Eclipse)
JAVAW caused an invalid page fault in
module KERNEL32.DLL at 0167:bff886d4.
Registers:
EAX=c00309c4 CS=0167 EIP=bff886d4 EFLGS=00010202
EBX=0057eda4 SS=016f ESP=00540000 EBP=0054008c
ECX=81980d90 DS=016f ESI=8197bbc8 FS=588f
EDX=bff76855 ES=016f EDI=005400a4 GS=0000
Bytes at CS:EIP:
55 8b ec 83 ec 0c a1 e4 9c fc bf 53 56 8b 0d e0
Stack dump:
bff87f0a 00000001 0000000e 005400a4 005400c0 00540268 8197bbc8 0057eda4
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Could you please tell me what I can do to solve this problem?
BTW, I tried, eclipse 2.0.2 in my computer, same problem.
Qhmd
Re: can not access help contents [message #63182 is a reply to message #62840] |
Wed, 04 June 2003 22:19   |
Originally posted by: birsan.nospam.ca.ibm.com
This could be caused by a back level version of Internet Explorer.
Do you have the latest updates (Windows + IE) installed? With eclipse 2.1
you'll need at least IE5.5
"qhmd" <hmdeng6@yahoo.com> wrote in message
news:bbll98$lmv$1@rogue.oti.com...
> Hello,
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> Thanks
> Qhmd
Re: can not access help contents [message #64244 is a reply to message #63182] |
Thu, 05 June 2003 13:37   |
IE in my computer is IE5.5, actually, I reinstalled IE 6.0, it still does
not work.Same problem, after select "help content", the message is as
follows
Javaw
This program has performed an illegal
operation and will be shut down.
If this persists, contact the program vendor.
I need to read the manual about Plug-in developer guide and some other
online help, so could you please help solve this problem?
Thanks.
Qhmd
> > Hello,
> > Registers:
> > Bytes at CS:EIP:
> > Stack dump:
> > Thanks
> > Qhmd
Re: can not access help contents [message #64471 is a reply to message #64244] |
Thu, 05 June 2003 15:35   |
As a work around, go to help preferences and switch to use a default system
browser instead of embedded one. If this helps, your problem might be
similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=29947 . You can
add yourself to the CC list, and append your findings (IE version, stack
dumps, whether there is anything on your machine that you think has a chance
of affecting working of embedded IE).
Konrad Kolosowski
"Qhmd" <hmdeng6@yahoo.com> wrote in message
news:bbnv59$eah$1@rogue.oti.com...
> Hello,
> follows
> Javaw
> Thanks.
> Qhmd
2.1
> > > Hello,
mark
the
> > > Registers:
> > > Bytes at CS:EIP:
> > > Stack dump:
0057eda4
00000000
> > > Thanks
> > > Qhmd
Re: can not access help contents [message #64791 is a reply to message #64471] |
Thu, 05 June 2003 18:57  |
Hello Konrad,
This time, it works after help preference is changed to default system
browser, I have added to the CC list.
Thanks.
> Konrad Kolosowski
> > Hello,
> > follows
> > Javaw
> > Thanks.
> > Qhmd
> 2.1
> > > > Hello,
> mark
> the
> > > > Registers:
> > > > Bytes at CS:EIP:
> > > > Stack dump:
> 0057eda4
> 00000000
> > > > Thanks
> > > > Qhmd
Current Time: Wed Jul 02 09:28:35 EDT 2025
Powered by FUDForum. Page generated in 0.59179 seconds
