checkbox in Preferences dialog not worked with AGR [message #62675] |
Thu, 30 March 2006 14:08 |
Originally posted by: vladimir.au.ru
I've found another problems with GUI recorder. I try to create the
following script:
- open preferences window (window->preferences)
- open java->compiler tab
- uncheck "Use default compliance settings"
I've recorded this scenario successfully and try to play it using "Quick
Run" button, but it failed with next exception:
There was an error while running the macro associated with the test case:
ModifyDefaultOptions. org.eclipse.core.runtime.CoreException: Line 13:
Cannot locate shell control:
org.eclipse.swt.widgets.Button#{{org.eclipse.jdt.internal.ui .preferences.OptionsConfigurationBlock$ControlData@1f6dbf5}}-{{1.0}}
Do you have any thoughts about it?
Vladimir.
FUDForum. Page generated in 0.04061 seconds
