Re: VE in WSAD 5.1 ? [message #6330 is a reply to message #5607] |
Fri, 28 November 2003 19:34 |
It should work fine. Of course, they are essentially the same, so what's
the motivation?
"S
Re: VE in WSAD 5.1 ? [message #6381 is a reply to message #5607] |
Fri, 28 November 2003 20:47 |
Originally posted by: mendelgili.netscape.net
Sébastien Alonzo wrote:
> I'm a bit curious wheiter or not the VE could be used with WSAD 5.1 :
> - VE 0.5.0 is based on Eclipse 2.1.2, GEF 2.1.2 and EMF 1.1.1
> - WSAD 5.1 is based on Eclipse 2.1.0
> So if I upgrade WSAD 5 to Eclipse 2.1.2 (I haven't tried so maybe it's not
> possible), then I can install VE 0.5.0 EMF 1.1.1 and GEF 2.1.2. Then what
> happens with the JVE which is shipped with WSAD 5 ?
> Can both editors coexist ? How to choose one form the other ? ...
> So, anybody has a clue about that ? (actually my question is for VE
> development team)
Not sure what is the goal; in any case, upgrading Eclipse on WSAD (as
well as EMF/GEF) would not be a supported WSAD configuration and is
likely to cause problems with various WSAD plugins.
Runing both VE and VEJ is not a supported configuration either. In the
future, WSAD will be based on IBM's WSWB (Eclipse) that will include VE
as the base for the VEJ.
FUDForum. Page generated in 0.06400 seconds
