Re: Generate Java code from UML model [message #62635] |
Fri, 19 June 2009 08:54 |
Originally posted by: rafael.abstratt.com
Michael, the UML2 Tools project deals with modeling only. You will find
3 different code generation solutions in the M2T project (which I added
to the CC list): XPand, Acceleo and JET. Here is the project web site:
http://www.eclipse.org/modeling/m2t/
Rafael
http://abstratt.com/blog/
Michael Gebhart wrote:
> I've created some UML models (class diagrams) and now, I want to
> generate the Java code skeletons. Is this possible?
> I've tried to convert the UML models to an Ecore model and gen model and
> generated the Java code. But now, I have my classes that inherit from
> EObject and the code contains a lot of annotations. I only want to
> generate plain Java objects. Is this possible with the Eclipse UML Tools
> (I am already testing the Galileo release). Or is there an open source
> plug-in available?
> Greetings
> Michael
Re: Generate Java code from UML model [message #62658 is a reply to message #62635] |
Fri, 19 June 2009 21:52 |
Timothy Marc Messages: 547 Registered: July 2009 |
Michael,
what you have done is, you've created an Ecore-based DSL of your model.
In this case, your UML instance model was converted into a arbitrary
metamodel (M2). What you wanted to do is to generate code out of UML
instance model.
Therefore, as Rafael mentioned, there are severals projects, but none
out-of-the-box-solution. I can recommend JET2 and Acceleo. I've worked
with both and they are feasible for your problem.
HTH
/Timothy
> Cheers,
> Rafael
>> and generated the Java code. But now, I have my classes that inherit
>> from EObject and the code contains a lot of annotations. I only want
>> to generate plain Java objects. Is this possible with the Eclipse UML
>> Tools (I am already testing the Galileo release). Or is there an open
>> source plug-in available?
>> Greetings
>> Michael
FUDForum. Page generated in 0.03557 seconds
