Tapestry + Hivemind + OSGI [message #62623] |
Sat, 25 February 2006 19:11 |
Originally posted by: iravana.gmail.com
I have read mentions of this configuration. Has anyone successfully done
this. If so, could you share some pointers/info with the rest of the group?
thanks
Re: Tapestry + Hivemind + OSGI [message #63475 is a reply to message #63267] |
Mon, 13 March 2006 17:17 |
Thank you Peter. I will take a look at the links you provided.
Peter Neubauer wrote:
> I have not done the integration, but over at ops4j we have done the same
> thing for Wicket with OSGi
> (http://wiki.ops4j.org/dokuwiki/doku.php?id=pax:wicket) which is quite
> similar. Beside that, some of this work has been done by inserting the DPML
> Metro object model (similar in functionality to OSGi) into Tapestry (
> https://scm.ops4j.org/repos/ops4j/projects/legacy/components /http/examples/hangman/).
> The docs are not generated right now, but I think it should not be too hard
> to at least get the BundleContext into the framework.
> Let me know if you are interested, and I can do a bit of digging.
> /peter
>> group?
>> thanks
FUDForum. Page generated in 0.04804 seconds
