Home » Modeling » OCL » Visibility of interface operations to implementing classifiers
| Visibility of interface operations to implementing classifiers [message #62619] |
Wed, 08 October 2008 16:23  |
Should interface operations be visible to their implementing classifiers
in OCL?
I'm using MDT OCL 1.2.0. I have a UML model containing Interface I with
a query operation <(param:I):Boolean, and a Class T that realizes I (but
does not own a corresponding query operation <(param:I):Boolean).
Another Class C has two attributes a1:T and a2:T. Using the OCL
Interpreter Example (evaluating for UML at the M1 modeling level), I
find that the following expression:
self.a1 < self.a2
fails to parse with the error: Cannot find operation (<(T)) for the type (T)
Is this the correct behaviour? I've verified that this same expression
parses without errors in MDT OCL 1.1.2.
Linda
| Re: Visibility of interface operations to implementing classifiers [message #62643 is a reply to message #62619] |
Wed, 08 October 2008 16:39   |
Originally posted by: cdamus.zeligsoft.com
Hi, Linda,
Does the class T happen to define an operation like this?
compareTo(T) : Integer
Or, does T correspond to an EClass whose instanceClass is of some
java.lang.Comparable type? In either case, the 1.1.x release would
infer the <(T):Boolean operation even if it wasn't defined. This is a
Java-ism that isn't applicable to OCL, so the 1.2 release corected that
by no longer making this inference. However, the 1.2 API does allow you
to restore the 1.1 behaviour by setting the
ParserOptions.USE_COMPARE_TO_OPERATION option. Try using the
ParserOption.setOption(...) method to set this option on your
environment before you parse (the root environment of your
org.eclipse.ocl.OCL façade is a good choice).
In any case, the Interface thing is a red herring. Classes don't
inherit features from the interfaces that they implement, so OCL won't
see a < operation in T unless T defines one or inherits it from another
class. Our UML binding has always respected that.
HTH,
Christian
> in OCL?
> self.a1 < self.a2
> (T)
> Linda
| Re: Visibility of interface operations to implementing classifiers [message #62668 is a reply to message #62643] |
Thu, 09 October 2008 09:57   |
--------------060200070408020004030700
T does not have any operations, actually. Nor does it correspond to an
EClass whose instanceClass is a java.lang.Comparable. I'm not sure why
the 1.1.2 release was able to see the < operation from the interface.
Given that classes don't inherit features from interfaces, is it because
of a defect that has subsequently been fixed in the 1.2.0 release?
I've attached a project that contains my .uml model, in case it helps to
clarify what I'm doing.
Linda
Christian W. Damus wrote:
> Hi, Linda,
| Re: Visibility of interface operations to implementing classifiers [message #62740 is a reply to message #62668] |
Thu, 09 October 2008 13:59   |
Hi, Linda,
Thanks for the attachment. I debugged it and have surprised myself.
The OCL 1.1 release has a bug, which evidently was fixed in 1.2 though I
don't remember it. In 1.1, the OclAny type from the OCL Standard
Library has all of the comparison operations <, <=, >, >=. This is at
odds with the OCL 2.0 specification, which defines only = and <> in the
OclAny context.
So, in 1.1.x, *all* types in the user model to have the comparison
operations imposed upon them. Happily, the 1.2 release fixes that :-)
Christian
> Linda
>> Hi, Linda,
>> that by no longer making this inference. However, the 1.2 API does
>> allow you to restore the 1.1 behaviour by setting the
>> another class. Our UML binding has always respected that.
>> HTH,
>> Christian
>>> classifiers in OCL?
>>> with a query operation <(param:I):Boolean, and a Class T that
>>> realizes I (but does not own a corresponding query operation
>>> <(param:I):Boolean). Another Class C has two attributes a1:T and
>>> a2:T. Using the OCL Interpreter Example (evaluating for UML at the
>>> M1 modeling level), I find that the following expression:
>>> self.a1 < self.a2
>>> type (T)
>>> expression parses without errors in MDT OCL 1.1.2.
>>> Thanks,
>>> Linda
| Re: Visibility of interface operations to implementing classifiers [message #63113 is a reply to message #62740] |
Tue, 14 October 2008 09:31   |
In MDT OCL 1.2.0, I see that implementation of
OCLStandardLibraryUtil#createAnyTypeOperations still seems to return <,
>, <= and >=. Is that correct?
Linda
> Hi, Linda,
> OclAny context.
> Cheers,
> Christian
>> why the 1.1.2 release was able to see the < operation from the
>> interface. Given that classes don't inherit features from interfaces,
>> is it because of a defect that has subsequently been fixed in the
>> 1.2.0 release?
>> to clarify what I'm doing.
>> Thanks,
>> Linda
>>> Hi, Linda,
>>> a Java-ism that isn't applicable to OCL, so the 1.2 release corected
>>> won't see a < operation in T unless T defines one or inherits it from
>>> HTH,
>>> Christian
>>>> classifiers in OCL?
>>>> self.a1 < self.a2
>>>> type (T)
>>>> Thanks,
>>>> Linda
| Re: Visibility of interface operations to implementing classifiers [message #63152 is a reply to message #63113] |
Tue, 14 October 2008 09:57  |
Hi, Linda,
This is necessary in order to enable the compatibility option, which
restores the former (incorrect) behaviour. An OCL 2.0 release would
remove them.
The OCLStandardLibraryUtil class should not be used by clients. The
@noreference tag defined by the PDE API Tools should be used to indicate
that (it isn't, currently). The exception to this rule is implementers
of metamodel bindings, but this API is only used in generating the OCL
Standard Library package, which otherwise is loaded by de-serialization
at run-time.
Christian
> Linda
>> Hi, Linda,
>> I don't remember it. In 1.1, the OclAny type from the OCL Standard
>> the OclAny context.
>> Cheers,
>> Christian
>>> an EClass whose instanceClass is a java.lang.Comparable. I'm not
>>> sure why the 1.1.2 release was able to see the < operation from the
>>> 1.2.0 release?
>>> Thanks,
>>> Linda
>>>> Hi, Linda,
>>>> from another class. Our UML binding has always respected that.
>>>> HTH,
>>>> Christian
>>>>> classifiers in OCL?
>>>>> self.a1 < self.a2
>>>>> type (T)
>>>>> Thanks,
>>>>> Linda
Current Time: Thu Oct 30 13:16:30 EDT 2025
Powered by FUDForum. Page generated in 0.04943 seconds
