Home » Language IDEs » Java Development Tools (JDT) » Q: Can JDT API be used headless?
Q: Can JDT API be used headless? [message #5600] Fri, 25 April 2003 17:37 Go to next message
Frank Sauer is currently offline Frank SauerFriend
I'm using the JDT API heavily in my metrics plugin, but now
would like to calculate the metrics as part of an automated
nightly build - from ant. Can the JDT API be used this way?
How does one find/access the workspace programmatically
in this scenario, if at all possible?
Frank Sauer
Re: Q: Can JDT API be used headless? [message #5629 is a reply to message #5600] Fri, 25 April 2003 19:18 Go to previous messageGo to next message
Originally posted by: jed_anderson.us.ibm.com
Frank,
I have written a tool that uses the JDT core headless, so I know that is
possible.
If you use just org.eclipse.jdt.core and org.eclipse.core.resources, you
can run headless and still access the workspace through normal means
(i.e. ResourcesPlugin.getWorkspace()).
jkca
> Frank Sauer
Re: Q: Can JDT API be used headless? [message #54384 is a reply to message #5600] Wed, 11 June 2003 11:03 Go to previous messageGo to next message
> Frank Sauer
Frank - I'm also trying to run the JDT core headless, have you had any
luck?
Thanks, Dennis
Re: Q: Can JDT API be used headless? [message #54408 is a reply to message #5629] Wed, 11 June 2003 11:13 Go to previous message
Jed:
Any chance you would be will to provide a snippet of code detailing how
you accomplished running the JDT core headless?
Thanks, Dennis
Jed Anderson wrote:
> Frank,
> possible.
> jkca
> > Regards,
> > Frank Sauer
Previous Topic:Threads and Monitors
Next Topic:NullPointerException at JavaCore.getOptions(JavaCore.java:1248)
Current Time: Sat Dec 21 13:54:33 GMT 2024
Powered by FUDForum. Page generated in 0.02961 seconds
