Installation issue [message #62573] |
Tue, 18 February 2003 16:47 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: acalifano.firstgenetic.net
I just installed Eclipse 2.0.2 (which seems to be the supported platform
for the CDT). After downloading the CDT zip and installing it in the
plugin directory, I received a message from Eclipse saying that the CDT
feature could not be properly configured because "the pluging
"org.eclipse.cdt.win32" version "1.0.1" referenced by this feature is
missing. included feature "org.eclipse.cdt_1.0.1" is missing"
Can anyone shed some light on this problem? Is that the right way to
install the plugin?
Thx!
Re: Installation issue [message #62671 is a reply to message #62620] |
Fri, 21 February 2003 05:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: orbitsim.hotmail.com
Judy N. Green wrote:
> "Andrea Califano" <acalifano@firstgenetic.net> wrote in message
> news:b2to3q$30b$1@rogue.oti.com...
> This is a known issue and there is a workaround on most systems ...
> Hi all,
> There have been some sporadic problems reported regarding installing the CDT
> in both Eclipse 2.0.x and 2.1.
> The following is a guide to installing the CDT and a workaround for this
> intermittent problem
> If you unzip the bin.dist.zip file into the eclipse directory:
> 1) Be sure that all previous installations of the CDT have
> been removed from your plugins and features directories
> 2) If the Install/Update manager will not let you install the CDT saying
> something to the effect of Eclipse C/C++ Development Tools (Windows)
> requires Eclipse C/C++ Development Tools 1.0.1
> a) Eclipse will still install the plugins but it will disable them.
> (Disabled plugins are not visible in the default view)
> b) In the Install/Update Perspective, Install Configuration View
> i) select the icon to show disabled features
> ii) The Eclipse C/C++ Development Tools (Windows) will show as
> disabled
> iii) Click the "Enable" button in the Details Preview View
> iv) Both plugins should now be fully enabled.
I am trying to get this installed on a XP box. Even with the above
mentioned work-around I am still not able to get CDT 1.0.1 installed on
Eclipse 2.0.2. I get an error meassage that says:
Error creating feature
"file:C:/eclipse/features/org.eclipse.cdt_1.0.1.jar/".[java.io.FilenotFoundException:
C:\eclipse\features\org.eclipse.cdt_1.0.1.jar\feature.xml (The system
cannot find the path specified)]
Am I missing something?
Dayne
Re: Installation issue [message #63082 is a reply to message #62620] |
Wed, 26 February 2003 00:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: davemedberry.myway.com
Thanks Judy, that worked for me.
For any other readers, the
Is in the top right hand corner of the Install Configuration pane (took me
awhile to find it....)
-dave
"Judy N. Green" <jgreen@qnx.com> wrote in message
news:b2u334$d4c$1@rogue.oti.com...
> | install the plugin?
> | Thx!
> Hi all,
CDT
> disabled
> I will continue to look into why this is happening and hope to have it
> solved in the near future
> -Judy
Re: Installation issue [message #64003 is a reply to message #62671] |
Wed, 05 March 2003 15:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: gdlxn.us.ibm.com
I'm also seeing the problem Dayne describes when trying to install CDT 1.01.
GA on IBM's WebSphere Studio Workbench 2.0.2 running on Windows 2000 SP 2.
Is there a workaround or fix?
Geoff Alexander
"Dayne Medlyn" <orbitsim@hotmail.com> wrote in message
news:b34e3e$vha$1@rogue.oti.com...
platform
> > Hi all,
CDT
> > disabled
xception:
> Dayne
FUDForum. Page generated in 0.03822 seconds
