svn metadata [message #5592] |
Thu, 28 September 2006 18:46 |
Originally posted by: thomas.spiessens.gmail.com
Hi everyone,
When I checkout a project using subclipse and another one using subversive and restart Eclipse again, how does Eclipse know that the first one should be under subclipse control and the other one under
subversive control ? Is there some metadata stored somewhere for each project ?
Thomas.
Re: svn metadata [message #5599 is a reply to message #5592] |
Thu, 28 September 2006 20:07 |
> project ?
Yes. Eclipse has a mapping of Team Providers to Projects that gets
setup when you do the checkout.
Mark
Re: svn metadata [message #5606 is a reply to message #5599] |
Thu, 28 September 2006 20:25 |
> Mark
Do you know where this information is stored (workspace metadata, ...) ? Is it in binary form or just plain text so I can take a look at it ?
Thomas.
Re: svn metadata [message #5613 is a reply to message #5606] |
Fri, 29 September 2006 00:24 |
> > Mark
> at it ?
Take a look at RepositoryProvider in org.eclipse.team.core
* Returns the provider for a given IProject or <code>null</code> if a
provider is not associated with
* the project or if the project is closed or does not exist. This
method should be called if the caller
* is looking for <b>any</b> repository provider. Otherwise call
<code>getProvider(project, id)</code>
* to look for a specific repository provider type.
* </p>
* @param project the project to query for a provider
* @return the repository provider associated with the project
final public static RepositoryProvider getProvider(IProject project) {
Mark
FUDForum. Page generated in 0.03504 seconds
