Re: AGR incorrectly records non-UI (programmatic) action and playback fails [message #63266 is a reply to message #62558] |
Sat, 01 April 2006 16:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
No real name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=amehrega%40ca.ibm.com) Messages: 404 Registered: July 2009 |
Hi Lior,
Yes, this is already a known issue. I have opened defect
https://bugs.eclipse.org/bugs/show_bug.cgi?id=110810 to resolve it. The
only workaround is to modify the macro or have the editor closed before
deleting the project.
"Lior David" <lior@e-sim.com> wrote in message
news:e0g7su$lqa$1@utils.eclipse.org...
> I have a problem with AGR recording. I recorded a simple test case with
> our custom plugin. In the test case I create a new project, which also
> opens an editor, and afterwards I delete the project from the eclipse
> navigator and check "also delete contents in filesystem". The delete
> operation automatically closes the open editor. In the generated macro,
> I see the following near the end:
> <shell
> id=" org.eclipse.ui.internal.progress.ProgressMonitorFocusJobDial og "
> return-code="0">
> <command type="close-workbenchpart" contextId="editor"
> widgetId="com.esim.eclipse.rapid.ui.UDOEditor/aaa.RXD"/>
> <command type="wait"/>
> </shell>
> This looks like the close action of our custom editor. However it should
> not be reocrded since it is closed programmatically and not as response
> to a user action. Also during playback AGR can't execute the action and
> reports timeout after a while.
> I tried recording a similar test case using the JDT, where I create a
> java project, new class and delete the project (which also closes the
> class editor) and in this case AGR does not record the close action.
> Both our plugin and JDT seem to use the same method to close the editor
> (WorkbenchPart.closeEditor).
> Before I investigate deeper, does anyone know if this is a known bug and
> if there is a workaround (one workaround is to close the editor manually
> before deleting the project).
> I am using AGR and TPTP from 02281515. We made some modifications to the
> AGR (mainly added a custom launcher needed by our plugin) but nothing
> related to the recording/playback that I know of.
> Lior
FUDForum. Page generated in 0.02756 seconds
