| SetCommand and the XSDSimpleTypeDefinition LexicalFinal attribute [message #62536] | Thu, 07 July 2005 17:27  |  |
| Eclipse User  |  |  |  |  | I attempted to set the LexicalFinal attribute on a XSDSimpleTypeDefinition instance using a SetCommand.  Unfortunately, the command fails preparation
 (SetCommand.prepare() returns false) because the string value does not match
 any of the enumeration literal values for this EAttribute.  The XSDSimpleTypeDefinitionItemProvider
 class creates a specialized ItemPropertyDescriptor for this attribute with
 the choice values representing all the various combinations of {restriction,
 list, union} - "restriction", "restriction list", "restriction list union",
 "restriction union", etc..  The EType for this property is XSD_SIMPLE_FINAL
 which only has the enumeration values of {all, restriction, list, union}
 so many of the choice values will never match the enumeration literal values
 and eType.isInstance(value) checks fail.  Can SetCommand not be used with
 the feature?  Is there a different way to set this feature value within the
 Command framework?
 Thanks in advance,
 Dennis Fuglsang
| Re: SetCommand and the XSDSimpleTypeDefinition LexicalFinal attribute [message #62561 is a reply to message #62536] | Thu, 07 July 2005 17:37  |  |
| Eclipse User  |  |  |  |  | Originally posted by: merks.ca.ibm.com
 Dennis,
 You need to create a list of XSDSimpleFinal values, not a String or list
 of Strings, as the value to set.
 > the command fails preparation (SetCommand.prepare() returns false)
 > because the string value does not match any of the enumeration literal
 > with the choice values representing all the various combinations of
 > {restriction, list, union} - "restriction", "restriction list",
 > "restriction list union", "restriction union", etc..  The EType for
 > this property is XSD_SIMPLE_FINAL which only has the enumeration
 > values of {all, restriction, list, union} so many of the choice values
 > will never match the enumeration literal values and
 > within the Command framework?
 > Thanks in advance,
 > Dennis Fuglsang
| Re: SetCommand and the XSDSimpleTypeDefinition LexicalFinal attribute [message #596078 is a reply to message #62536] | Thu, 07 July 2005 17:37  |  |
| Eclipse User  |  |  |  |  | Dennis,
 > Thanks in advance,
 > Dennis Fuglsang
FUDForum. Page generated in 0.04267 seconds
