Re: Tile Editors in editorarea programmatically [message #62701 is a reply to message #62562] |
Wed, 04 June 2003 17:53 |
Originally posted by: simon.ibm.oti.lab
"MorPheus" <rgurupackiam@selectica.com> wrote: "I wonder why the eclipse
doesn't provide API for"
The same reason(s) you give a client of your application when the client ask
"how come you did not include feature ABC?". There are many things included
in eclipse, and many more missing too. Its a question of time, priority,
complexity, value, etc.
You can open an enhancement bug report against Platform - UI for it to be
considered. Or maybe your company is willing to commit a number of
developers to add this feature in and have it included in Eclipse. If so,
please post a message in the platform-ui-dev mailing list.
Simon :-)
"MorPheus" <rgurupackiam@selectica.com> wrote in message
news:bbl5ad$84b$1@rogue.oti.com...
> Hi Simon,
> Hi Simon,
> I think today is my unlucky day. I got two negative responses from you. I
> wonder why the eclipse doesn't provide API for programmatically setting
the
> layout of the editor that would change the default stacked layout to tiled
> layout because I feel this as restriction imposed on the developers. I
also
> feel the functionality is really needed because we cannot force the end
user
> or assume the end user will be knowing how to set the editor layout
> manually. They should be able to get the desired layout by click of a
> button. Need your comments and suggestions
> MorPheus
> "Simon Arsenault" <simon@ibm.oti.lab> wrote in message
> news:bbl4dh$74j$1@rogue.oti.com...
> > no
> > Simon :-)
> > news:bbl417$6nr$1@rogue.oti.com...
> > > Hi,
> > > I know we can tile the editor working area manually by using drag
> and
> > > drop.But is it possible to set the tile as the default layout of the
> > editor
> > > area programmatically, so that whenever two editors are opened in the
> > > editor area,we will be able to see the two editors in tiled layout.
> > > MorPheus
FUDForum. Page generated in 0.03426 seconds
