Re: Xtext Editor as a standalone application? [message #62505 is a reply to message #62450] |
Wed, 22 July 2009 12:42 |
Originally posted by: oba.informatik.uni-kiel.de
Hi Ilyas,
you could use the message with the subject "[XText] a standalone Java
application that parses text to model"
Good luck
mN
Ilyas Keser wrote:
> Hi @all,
> is it possible to use the generated DSL editor as a standalone
> application (without Eclipse)?
> ILyas
Re: Xtext Editor as a standalone application? [message #62845 is a reply to message #62505] |
Wed, 22 July 2009 16:47 |
Originally posted by: ilyas.keser.gmail.com
Hi mN,
thanks for your reply.
If I understood the example correctly, one can parse with XtextResource
a resource and get the parse result. OK, but XtextResource doesn't offer
methods to run/start the editor? Any ideas?
ILyas
myName schrieb:
> Hi Ilyas,
> Good luck
> mN
> Ilyas Keser wrote:
>> Hi @all,
>> Thanks,
>> ILyas
Re: Xtext Editor as a standalone application? [message #62956 is a reply to message #62934] |
Fri, 24 July 2009 08:46 |
Hi Sebastian & Jos,
thanks for your answers. My question was about an application which only
shows the generated Xtext editor. You can then give this tool to users
of your DSL (yes, non programmers) to provide a nice editor for model
editing.
If I use a minimal Eclipse distro is it possible to show only the editor
and hide everything else? With "everything else" I mean other views and
windows of Eclipse like Project Explorer or Console...
ILyas
Jos Warmer schrieb:
> Sebastian,
> I remember that the GMF generator somewhere has en option to generate a
> standalone editor. The result is a downsized Eclipse application with
> only the GMF plugin available. People using this standalone version can
> only create and edit model files of this DSL and nothing else.
> This is useful if your DSL is used by non programmers and you don't want
> to expose all of Eclipse to them, but a sim0plified environment instead.
> Jos
> Sebastian Zarnekow wrote:
>> Hi Ilyas,
>> Xtext creates Eclipse plugins. What do you mean with "editor without
>> Eclipse"? You may want to use the runtime part in standalone mode and
>> create all the ui infrastructure yourself. It is easier to provide a
>> minimal Eclipse distro (with Eclipse - whatever that means) that
>> contains the editor plugin.
>> Regards,
>> Sebastian
Re: Xtext Editor as a standalone application? [message #62960 is a reply to message #62956] |
Fri, 24 July 2009 08:52 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Ilyas,
yes thats possible. You can remove almost anything from Eclipse (with
respect to the dependencies of the Editor).
There are various tutorials about pde development and product packaging
out there - I think google will be your friend :-).
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 24.07.2009 10:46 Uhr, schrieb Ilyas Keser:
> Hi Sebastian & Jos,
> editing.
> ILyas
> Jos Warmer schrieb:
>> Sebastian,
>> a standalone editor. The result is a downsized Eclipse application
>> with only the GMF plugin available. People using this standalone
>> version can only create and edit model files of this DSL and nothing
>> else.
>> want to expose all of Eclipse to them, but a sim0plified environment
>> instead.
>> Jos
>>> Hi Ilyas,
>>> Regards,
>>> Sebastian
FUDForum. Page generated in 0.04149 seconds
