Multi-dirrectory output [message #62424] |
Fri, 03 March 2006 13:22 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: a.shneyderman.gmail.com
In my project I have two source folders main/java & test/java. When I
write an abstract object that only needs a pointcut in its concrete
implementation, I would write it inlined in my test. This means that the
test directory does have an aspect but I do not want to package it. While
main/java source' output is the one I want to take and package.
AJDT (and I suppose it is an ajc fault) has a problem with outputing
compiled code to 2 separate output directories, therefore does output
classes into the default directory, which cause me a lot of pain.
Is there a work around this limitation or maybe a solution that I
overlooked?
alex.
FUDForum. Page generated in 0.03915 seconds
