More control over Eclipse builders [message #62365] |
Wed, 20 May 2009 22:47 |
Originally posted by: bluedoze.gmail.com
I'm looking for a way to get more control over Eclipse builders, like
the ability to invoke the builder multiple times in a loop, or break the
whole build if one of multiple builders encountered an error.
I saw that eclipse calls the builders in BuildManager class, but I
didn't see any extension points or a way to extend/replace this class.
Are there any other way to get more control over the builders? Any help
is appreciated.
Re: More control over Eclipse builders [message #62510 is a reply to message #62438] |
Thu, 21 May 2009 22:35 |
I'm in a situation where the builders are dependent and I don't have
control over some of them, they are delivered to me, so I want to be
able to run them only if the previous builders finished correctly, and
run them multiple times on multiple input.
Dann Martens wrote:
> It's not clear on what you're trying to achieve; my first instinctual
> reaction would be to question why your requirements would make sense.
> Are you considering this for the builder stack of a single project, or
> are you looking for ways to coordinate builders across multiple projects?
> I've always approached a builder as self-contained, and the building
> operation itself as atomic.
> Best,
> Dann
> Bluedoze wrote:
>> the whole build if one of multiple builders encountered an error.
>> help is appreciated.
>> Thanks
Re: More control over Eclipse builders [message #597724 is a reply to message #62438] |
> Best,
> Dann
> Bluedoze wrote:
>> Thanks
FUDForum. Page generated in 0.03019 seconds
