Home » Eclipse Projects » Plugin Development Environment (PDE) » More control over Eclipse builders
More control over Eclipse builders [message #62365] Wed, 20 May 2009 18:47 Go to next message
Originally posted by: bluedoze.gmail.com
I'm looking for a way to get more control over Eclipse builders, like
the ability to invoke the builder multiple times in a loop, or break the
whole build if one of multiple builders encountered an error.
I saw that eclipse calls the builders in BuildManager class, but I
didn't see any extension points or a way to extend/replace this class.
Are there any other way to get more control over the builders? Any help
is appreciated.
Re: More control over Eclipse builders [message #62438 is a reply to message #62365] Thu, 21 May 2009 05:15 Go to previous messageGo to next message
It's not clear on what you're trying to achieve; my first instinctual
reaction would be to question why your requirements would make sense.
Are you considering this for the builder stack of a single project, or
are you looking for ways to coordinate builders across multiple projects?
I've always approached a builder as self-contained, and the building
operation itself as atomic.
Best,
Dann
Bluedoze wrote:
> is appreciated.
> Thanks
Re: More control over Eclipse builders [message #62510 is a reply to message #62438] Thu, 21 May 2009 18:35 Go to previous message
I'm in a situation where the builders are dependent and I don't have
control over some of them, they are delivered to me, so I want to be
able to run them only if the previous builders finished correctly, and
run them multiple times on multiple input.
> Best,
> Dann
> Bluedoze wrote:
>> the whole build if one of multiple builders encountered an error.
>> help is appreciated.
>> Thanks
Re: More control over Eclipse builders [message #597702 is a reply to message #62365] Thu, 21 May 2009 05:15 Go to previous message
Best,
Dann
Bluedoze wrote:
> is appreciated.
> Thanks
Re: More control over Eclipse builders [message #597724 is a reply to message #62438] Thu, 21 May 2009 18:35 Go to previous message
> Best,
> Dann
> Bluedoze wrote:
>> Thanks
Previous Topic:Update Manager port?
Next Topic:PDE Build, SVN and jar qualifiers
Current Time: Fri Oct 24 01:45:47 EDT 2025
Powered by FUDForum. Page generated in 0.25968 seconds
