Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO and SessionInvalidationListener
CDO and SessionInvalidationListener [message #62357] Mon, 20 November 2006 11:56 Go to next message
Originally posted by: yannick.lizzi.silogic.fr
Hi all,
I have the following model:
Meeting #-> User (aggregation), named "participants"
Session --> Meeting (association)
Session --> User (association), named "queue".
I have two clients and one server. My purpose is to maintain the 'queue'
relation up to date on both client sides.
When I add a user (already defined in meeting aggregation) to the queue
on one side, I see it on the other side. But when I remove a user the
other side is not notified.
I use the following session invalidation listener:
class SessionInvalidationListener implements
ResourceManager.InvalidationListener {
public void notifyInvalidation(ResourceManager manager,
List<EObject> invalidated, List<EObject> deferred) {
for (EObject o : invalidated) {
CDOPersistent cdoObj = (CDOPersistent) o;
cdoObj.load(); // Used to notify my viewer listening to model changes
// the following is for test only
if (cdoObj instanceof Session) {
Session s = (Session) cdoObj;
System.out.println("queue="+s.getQueue());
When I add a user to the queue, the queue is modified. But when a user
is removed the queue is always displaying the state before the remove.
Yannick
Re: CDO and SessionInvalidationListener [message #62381 is a reply to message #62357] Mon, 20 November 2006 13:27 Go to previous messageGo to next message
Yannick,
Eike is on vacation until Dec 6 so likely you won't get an answer before
then.
Yannick Lizzi wrote:
> Hi all,
> 'queue' relation up to date on both client sides.
> queue on one side, I see it on the other side. But when I remove a
> user the other side is not notified.
> changes
> Yannick
Re: CDO and SessionInvalidationListener [message #62634 is a reply to message #62357] Fri, 24 November 2006 00:35 Go to previous messageGo to next message
Originally posted by: sperez.miragenetworks.com
I see the same thing (or something very similar). Specifically, in
AbstractDataRequest.receiveObject(...), I see where the new objects are
added in receiveReferences(...), but I see no place where a removed object
gets removed.
In my specific use case I am moving an object from a non-containment
reference of one object to another. When the object is moved from one list
to the other, the object apears to be in both lists.
Patiently waiting until Dec. 6,
Stephen
"Yannick Lizzi" <yannick.lizzi@silogic.fr> wrote in message
news:ejsmni$5a7$1@utils.eclipse.org...
> Hi all,
> When I add a user (already defined in meeting aggregation) to the queue on
> one side, I see it on the other side. But when I remove a user the other
> public void notifyInvalidation(ResourceManager manager, List<EObject>
> When I add a user to the queue, the queue is modified. But when a user is
> Yannick
Re: CDO and SessionInvalidationListener [message #64612 is a reply to message #62357] Sat, 16 December 2006 04:36 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Yannick, Stephen,
Sorry for the delay, but I'm starting to dig into this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168321
Cheers
/Eike
Yannick Lizzi schrieb:
> Hi all,
> changes
> Yannick
Re: CDO and SessionInvalidationListener [message #64887 is a reply to message #64612] Tue, 19 December 2006 10:13 Go to previous messageGo to next message
Yannick, Stephen,
I have fixed this bug and committed the changes to branch
R0_7_maintenance. Unfortunately the build system is not usable for me at
the moment. As soon as it is I will publish new builds.
Cheers
/Eike
Eike Stepper schrieb:
> Yannick, Stephen,
> Cheers
> /Eike
>> Hi all,
>> changes
>> user is removed the queue is always displaying the state before the
>> remove.
>> Thanks,
>> Yannick
Re: CDO and SessionInvalidationListener [message #65280 is a reply to message #64887] Thu, 21 December 2006 06:02 Go to previous message
Eike,
Now, it works thanks.
Yannick
> Yannick, Stephen,
> Cheers
> /Eike
>> Yannick, Stephen,
>> Cheers
>> /Eike
>>> Hi all,
>>> changes
>>> remove.
>>> Thanks,
>>> Yannick
Re: CDO and SessionInvalidationListener [message #596006 is a reply to message #62357] Mon, 20 November 2006 13:27 Go to previous message
Yannick,
then.
> Hi all,
> changes
> Yannick
Re: CDO and SessionInvalidationListener [message #596120 is a reply to message #62357] Fri, 24 November 2006 00:35 Go to previous message
gets removed.
Stephen
> Hi all,
> Yannick
Re: CDO and SessionInvalidationListener [message #596956 is a reply to message #62357] Sat, 16 December 2006 04:36 Go to previous message
Yannick, Stephen,
Cheers
/Eike
> Hi all,
> changes
> Yannick
Re: CDO and SessionInvalidationListener [message #597090 is a reply to message #64612] Tue, 19 December 2006 10:13 Go to previous message
Yannick, Stephen,
Cheers
/Eike
> Yannick, Stephen,
> Cheers
> /Eike
>> Hi all,
>> changes
>> remove.
>> Thanks,
>> Yannick
Re: CDO and SessionInvalidationListener [message #597270 is a reply to message #64887] Thu, 21 December 2006 06:02 Go to previous message
Eike,
Yannick
> Yannick, Stephen,
> Cheers
> /Eike
>> Yannick, Stephen,
>> Cheers
>> /Eike
>>> Hi all,
>>> changes
>>> remove.
>>> Thanks,
>>> Yannick
Previous Topic:[Teneo] Setting Id generator from ecore file
Next Topic:How to programmatically generate editor code from .ecore file
Current Time: Wed Apr 16 13:21:06 EDT 2025
Powered by FUDForum. Page generated in 0.04253 seconds
