Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » CDO and SessionInvalidationListener
CDO and SessionInvalidationListener [message #62357] |
Mon, 20 November 2006 16:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: yannick.lizzi.silogic.fr
Hi all,
I have the following model:
Meeting #-> User (aggregation), named "participants"
Session --> Meeting (association)
Session --> User (association), named "queue".
I have two clients and one server. My purpose is to maintain the 'queue'
relation up to date on both client sides.
When I add a user (already defined in meeting aggregation) to the queue
on one side, I see it on the other side. But when I remove a user the
other side is not notified.
I use the following session invalidation listener:
class SessionInvalidationListener implements
ResourceManager.InvalidationListener {
public void notifyInvalidation(ResourceManager manager,
List<EObject> invalidated, List<EObject> deferred) {
for (EObject o : invalidated) {
CDOPersistent cdoObj = (CDOPersistent) o;
cdoObj.load(); // Used to notify my viewer listening to model changes
// the following is for test only
if (cdoObj instanceof Session) {
Session s = (Session) cdoObj;
System.out.println("queue="+s.getQueue());
When I add a user to the queue, the queue is modified. But when a user
is removed the queue is always displaying the state before the remove.
Yannick
Re: CDO and SessionInvalidationListener [message #62381 is a reply to message #62357] |
Mon, 20 November 2006 18:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yannick,
Eike is on vacation until Dec 6 so likely you won't get an answer before
then.
Yannick Lizzi wrote:
> Hi all,
> 'queue' relation up to date on both client sides.
> queue on one side, I see it on the other side. But when I remove a
> user the other side is not notified.
> changes
> Yannick
Re: CDO and SessionInvalidationListener [message #62634 is a reply to message #62357] |
Fri, 24 November 2006 05:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sperez.miragenetworks.com
I see the same thing (or something very similar). Specifically, in
AbstractDataRequest.receiveObject(...), I see where the new objects are
added in receiveReferences(...), but I see no place where a removed object
gets removed.
In my specific use case I am moving an object from a non-containment
reference of one object to another. When the object is moved from one list
to the other, the object apears to be in both lists.
Patiently waiting until Dec. 6,
Stephen
"Yannick Lizzi" <yannick.lizzi@silogic.fr> wrote in message
news:ejsmni$5a7$1@utils.eclipse.org...
> Hi all,
> When I add a user (already defined in meeting aggregation) to the queue on
> one side, I see it on the other side. But when I remove a user the other
> public void notifyInvalidation(ResourceManager manager, List<EObject>
> When I add a user to the queue, the queue is modified. But when a user is
> Yannick
Re: CDO and SessionInvalidationListener [message #64612 is a reply to message #62357] |
Sat, 16 December 2006 09:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: stepper.sympedia.de
Yannick, Stephen,
Sorry for the delay, but I'm starting to dig into this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=168321
Cheers
/Eike
Yannick Lizzi schrieb:
> Hi all,
> changes
> Yannick
Re: CDO and SessionInvalidationListener [message #64887 is a reply to message #64612] |
Tue, 19 December 2006 15:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yannick, Stephen,
I have fixed this bug and committed the changes to branch
R0_7_maintenance. Unfortunately the build system is not usable for me at
the moment. As soon as it is I will publish new builds.
Cheers
/Eike
Eike Stepper schrieb:
> Yannick, Stephen,
> Cheers
> /Eike
>> Hi all,
>> changes
>> user is removed the queue is always displaying the state before the
>> remove.
>> Thanks,
>> Yannick
Re: CDO and SessionInvalidationListener [message #65280 is a reply to message #64887] |
Thu, 21 December 2006 11:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Eike,
Now, it works thanks.
Yannick
> Yannick, Stephen,
> Cheers
> /Eike
>> Yannick, Stephen,
>> Cheers
>> /Eike
>>> Hi all,
>>> changes
>>> remove.
>>> Thanks,
>>> Yannick
Re: CDO and SessionInvalidationListener [message #596006 is a reply to message #62357] |
Mon, 20 November 2006 18:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33195 Registered: July 2009 |
Yannick,
then.
> Hi all,
> changes
> Yannick
Ed Merks
Re: CDO and SessionInvalidationListener [message #596120 is a reply to message #62357] |
Fri, 24 November 2006 05:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
gets removed.
Stephen
> Hi all,
> Yannick
Re: CDO and SessionInvalidationListener [message #596956 is a reply to message #62357] |
Sat, 16 December 2006 09:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Yannick, Stephen,
Cheers
/Eike
> Hi all,
> changes
> Yannick
Cheers
/Eike
http://www.esc-net.de
Re: CDO and SessionInvalidationListener [message #597090 is a reply to message #64612] |
Tue, 19 December 2006 15:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Yannick, Stephen,
Cheers
/Eike
> Yannick, Stephen,
> Cheers
> /Eike
>> Hi all,
>> changes
>> remove.
>> Thanks,
>> Yannick
Cheers
/Eike
Re: CDO and SessionInvalidationListener [message #597270 is a reply to message #64887] |
Eike,
Yannick
> Yannick, Stephen,
> Cheers
> /Eike
>> Yannick, Stephen,
>> Cheers
>> /Eike
>>> Hi all,
>>> changes
>>> remove.
>>> Thanks,
>>> Yannick
Current Time: Thu Aug 15 19:36:21 GMT 2024
Powered by FUDForum. Page generated in 0.04091 seconds
