Home » Archived » Visual Editor (VE) » Adding JScrollPanes around JLists
Adding JScrollPanes around JLists [message #5540] Tue, 25 November 2003 19:30 Go to next message
Is it possible, using VE, to place a JList inside a ScollPane? I'm sure
one could hack the SDK to expose this, but I'm hesitant to get myself
enmeshed in yet more code. But I'd hope to finish setting this up as
visually as possible.
Re: Adding JScrollPanes around JLists [message #5546 is a reply to message #5540] Tue, 25 November 2003 19:40 Go to previous messageGo to next message
Originally posted by: jdm0532.nospam.cs.rit.edu
Yes, you should be able to do this, but there's not a combined palette
item like JTable on JScrollPane. Simply drop the JScrollPane first
(from the Swing Containers drawer) then the JList on top of that. It
might be easier to get the child relationship right if you drop the
JList onto the JScrollPane on the Java Beans Viewer.
- Jeff Myers
Re: Adding JScrollPanes around JLists [message #5551 is a reply to message #5546] Tue, 25 November 2003 21:18 Go to previous messageGo to next message
Got it, thanks for the help.
It's worth noting that the combined object seems harder to manipulate
than the individual objects--it doesn't offer resize corners, and can't
be aligned.
Danyel
> - Jeff Myers
>> sure one could hack the SDK to expose this, but I'm hesitant to get
>> myself enmeshed in yet more code. But I'd hope to finish setting this
>> up as visually as possible.
Re: Adding JScrollPanes around JLists [message #5569 is a reply to message #5551] Tue, 25 November 2003 22:00 Go to previous message
The problems you're having with manipulating the combined object are
most likely occurring because you have the JList selected rather than
the JScrollPane. It's impossible to select the JScrollPane on the
canvas surface. You'll have to select the scroll pane on the Java Beans
Viewer, then perform the resize/align actions without losing the focus
on it on the canvas.
- Jeff Myers
> be aligned.
> Danyel
>> - Jeff Myers
Re: Adding JScrollPanes around JLists [message #569255 is a reply to message #5540] Tue, 25 November 2003 19:40 Go to previous message
- Jeff Myers
Re: Adding JScrollPanes around JLists [message #569291 is a reply to message #5546] Tue, 25 November 2003 21:18 Go to previous message
be aligned.
Danyel
> - Jeff Myers
Re: Adding JScrollPanes around JLists [message #569415 is a reply to message #5551] Tue, 25 November 2003 22:00 Go to previous message
- Jeff Myers
> be aligned.
> Danyel
>> - Jeff Myers
Previous Topic:Dropping to inconsistent states
Next Topic:VE do not work with Eclipse fpr OSX
Current Time: Thu Oct 16 00:14:10 EDT 2025
Powered by FUDForum. Page generated in 0.03847 seconds
