Re: [ATL] Nesting classes in corresponding package [message #62100 is a reply to message #62030] |
Fri, 21 September 2007 19:18 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
Hi Swetha,
You may also want to have a look at the UML to MOF 1.4 transformation
available in the ATL transformation zoo:
http://www.eclipse.org/m2m/atl/atlTransformations/#UML2MOF
Regarding file attachments: I believe the portal is merely offered as a
convenience, which is limited in functionality. If you really want to
use all the powerful newsgroup functionalities, then you probably need
to get a news client (e.g., Thunderbird).
Frédéric Jouault
Freddy Allilaire wrote:
> Hi Swetha,
> The assignment of a class into its respective package will be done by
> the ATL Resolve Algorithm.
> I advise you to take a look to the following article/example (especially
> section 6):
> http://www.eclipse.org/m2m/atl/basicExamples_Patterns/Tree2L ist/
> Best regards,
> Freddy.
> Swetha a écrit :
>> I have two metamodels (uml and ecore).Can you please tell me
>> 1) how do i assign classes in their respective package?I am trying to
>> do the transformation from uml to ecore using ATL.
>> If you want me to send the metamodels can you please tell me how do i
>> attach the same in this portal since i can't see any such feature?
>> Please reply at the earliest.
>> Regards,
>> Swetha.
FUDForum. Page generated in 0.04114 seconds
