Re: ANT with JDK1.3 and additional tasks [message #62217 is a reply to message #61999] |
Wed, 04 June 2003 13:07 |
Originally posted by: hcs33.egon.gyaloglo.hu
Did you also add the additional tasks to the Tasks page in Ant-->Runtime
preferences? If not, that might be the problem.
HTH,
Csaba
"Jochen Vogele" <vogele@media-saturn.com> wrote in message
news:bbkg40$iv0$1@rogue.oti.com...
> Hello all,
> i'm starting eclipse with jdk1.3.1_07 and want to build my project with an
> ant build. I'm using some additional tasks like AntDoc for which i add the
> AntDoc.jar to the "additional classpath entries" of the ant preferences.
I'm
> setting the virtual machine as a start parameter of eclipse, so the
> tools.jar is there in the runtime classpath.
> If i start the build file (via right click "run ant) the following output
is
> created:
> [taskdef] BUILD FAILED:
> file:W:/WWSNG_MobilePOS/P3_Impl/Java/build/build_internal.xm l:336: taskdef
> class org.ed.pack.ant.AntDoc cannot be found
> The class is in the jar file i added ... the strange thing: if i'm
starting
> eclipse with jdk1.4 everthing works fine, but i need to compile the
project
> with jdk1.3 :(
> any suggestions, solutions, hints ?
> thanx in advance,
> jochen
FUDForum. Page generated in 0.02743 seconds
