Home » Modeling » TMF (Xtext) » Sharing imported dsl files witch custom URI
Re: Sharing imported dsl files witch custom URI [message #481743 is a reply to message #481705] |
Mon, 24 August 2009 07:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Sebastian Zarnekow![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=sebastian.zarnekow%40gmail.com) Messages: 3118 Registered: July 2009 |
Hi Stefano,
the linking and content assist use an implementation of the
IScopeProvider interface to calculate all available instances. If you
plug you own implementation, you can pretty much return a scope that
contains anything you want - even the elements from other model files in
the very same directory. It is possible to traverse the current input
model, collect all import statements and resolve them in the way you
like (with wildcards or without...). Xtext ships with some reasonable
defaults that are a good match for many use cases but in your scenario,
you'll have to implement a custom scope provider.
The reference documentation (http://www.xtext.org) and the source code
of Xtext will be a good starting point to learn about scoping.
If you have any further questions, please don't hesitate to ask.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 23.08.09 22:04, schrieb Stefano Cottafavi:
> Hi Sebastian,
> I'm not used to do tricky things with Xtext, till now I focused only on
> the appearence of editor and outline view for my dsl.
> About the wildcard I really don't know how to code your suggestions.
> Please, is there some snippet of code you can suggest me. Everything
> will be appreciated laso useful links or docs.
> Btw thank you very much for the effort you and your colleagues put into
> helping people via this forum.
> Cheers
> Stefano
Re: Sharing imported dsl files witch custom URI [message #487209 is a reply to message #487100] |
Tue, 22 September 2009 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Stefano,
what do you mean by "I'm not able to add resources to the resource set".
Do you get any exceptions?
context.eResource().getResourceSet().getResource(uri, true) should work.
Sebastian
Stefano Cottafavi schrieb:
> Hi Sebastian,
> after a while I'm here with little code for the getScope method
> public IScope getScope(EObject context, EReference reference) {
> URI uri = context.eResource().getURI();
> String ext = uri.fileExtension();
> if(ext.matches("dat")) {
> List<IScopedElement> allElems = new
> ArrayList<IScopedElement>();
> IWorkspaceRoot wsr =
> ResourcesPlugin.getWorkspace().getRoot();
> IPath path = wsr.getFile(new
> Path(uri.toPlatformString(false))).getLocation();
> File[] flist =
> path.toFile().getParentFile().listFiles();
> for(File f:flist) {
> //Resource r =
> context.eResource().getResourceSet().createResource(URI.crea teFileURI(f.getAbsolutePath()));
> Resource r =
> ImportUriUtil.getResource(context.eResource(),f.toURI().toSt ring());
> context.eResource().getResourceSet().getResources().add(r);
> Model m = (Model)r.getContents().get(0);
> List<SectionKeyword> sk = m.getOptional();
> for(SectionKeyword nk:sk){ // loop
> section keywords
> for(EObject d:nk.eContents()){ // loop name
> keywords
> String name = d.eContents().get(0).toString();
> allElems.add(ScopedElement.create(name, d));
> Scope scope = new Scope();
> scope.setElements(allElems);
> return scope;
> return super.getScope(context, reference);
> The idea is to get all files (.dat) in a folder and add their content to
> the returned scope, with no import statement but retrieving the path
> from eResource.
> I'm not able to add File (all the File in the for loop) to the
> resourceset. how can this be done? talking about hte overall method to
> build the scope, is this good? any suggestion?
> Cheers,
> Stefano
Re: Sharing imported dsl files witch custom URI [message #493369 is a reply to message #61741] |
Sun, 25 October 2009 11:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Stefano Cottafavi![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=stefano.cottafavi%40gmail.com) Messages: 57 Registered: July 2009 |
Member |
Hi Sebastian,
after a while I found a solution that do what I want. Here's the code
private Scope internalGetScope(EObject context, EReference reference) {
if(internalScope==null) {
List<IScopedElement> allElems = new ArrayList<IScopedElement>();
IWorkspaceRoot wsr = ResourcesPlugin.getWorkspace().getRoot();
IPath path = wsr.getFile(new Path(uri.toPlatformString(false))).getLocation();
File[] flist = path.toFile().getParentFile().listFiles(fileFilter);
for(File f:flist) {
Resource r = ImportUriUtil.getResource(context.eResource(),f.toURI().toString());
List<SectionKeyword> skl = m.getOptional();
for(SectionKeyword sk:skl){ // loop section keywords
List<NameKeyword> nkl = sk.getSection();
for(NameKeyword nk:nkl){ // loop name keywords
allElems.add(ScopedElement.create(nk.getName(), nk));
internalScope = new Scope();
internalScope.setOuterScope(super.getScope(context, reference).getOuterScope());
internalScope.setElements(allElems);
return internalScope;
In my intention check if internalscope is already defined, should prevent for contexts in the same file to re-loop/re-build every time the same scope.
Now another question rise: scenario is that I have this folder with a large number of files (every one with large number of model's objects inside). Every file in this folder would share the same scope. Now, when I open a file in the editor from that folder the scope is built (this take some seconds and for the moment I can leave with that); when another file from the same folder is opened too, the scope is rebuilt, and that's something I would avoid.
How can I share the scope between files/resources?
Stefano
Re: Sharing imported dsl files witch custom URI [message #494364 is a reply to message #493369] |
Fri, 30 October 2009 12:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Stefano,
I'm not sure about your approach. Have you evaluated the EMF Index
project and the index based scope provider?
However: You could extract that internalGetScope implementation into
another class, annotate it with @Singleton and inject this
implementation into your scope provider.
This would ensure, that any scope provider uses the same internalScope.
Sebastian
> Hi Sebastian,
> File[] flist =
> for(File f:flist) {
> Resource r =
> section keywords
> name keywords
> nk));
> same scope.
> Stefano
Current Time: Wed Jul 17 01:34:38 GMT 2024
Powered by FUDForum. Page generated in 0.05014 seconds
