Home » Language IDEs » AspectJ » Error creating advice
Error creating advice [message #61682] Mon, 06 February 2006 10:36 Go to next message
Originally posted by: kanonmicke.gmail.com
Hi!
I wonder if anybody have had these problems and know a workaround or a
solution.
Im using eclipse 3.1.0 and have downloaded and installed
ajdt_1.3_for_eclipse_3.1.zip. I using jdk1.5.
After converting my existing project to a aspectj project I
get the following exceptions:
Unhandled event loop exception
An exception stack trace is not available.
Failed to execute runnable (java.lang.VerifyError: class
org.eclipse.ajdt.internal.ui.editor.contentassist.AJCompleti onProcessor
overrides final method .)
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:3251)
at org.eclipse.swt.SWT.error(SWT.java:3174)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3171)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2826)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1755)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1719)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:368)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:106)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:377)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:164)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.VerifyError: class
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:68)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.ajdt.internal.ui.editor.AJSourceViewerConfigurat ion.getContentAssistant(AJSourceViewerConfiguration.java:58)
org.eclipse.jface.text.source.SourceViewer.configure(SourceV iewer.java:331)
org.eclipse.jdt.internal.ui.javaeditor.JavaSourceViewer.conf igure(JavaSourceViewer.java:214)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor $AdaptedSourceViewer.configure(CompilationUnitEditor.java:31 4)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2532)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:326)
org.eclipse.jdt.internal.ui.javaeditor.JavaEditor.createPart Control(JavaEditor.java:2628)
org.eclipse.jdt.internal.ui.javaeditor.CompilationUnitEditor .createPartControl(CompilationUnitEditor.java:1725)
org.eclipse.ajdt.internal.ui.editor.AspectJEditor.createPart Control(AspectJEditor.java:325)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:599)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:374)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:213)
org.eclipse.ajdt.internal.builder.AJModelUtils$RefreshOutlin ePagesJob.runInUIThread(AJModelUtils.java:78)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:93)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
I also get the exact same errors creating an aspect following the
HelloWorld example, http://www.eclipse.org/ajdt/demos/index.php.
Re: Error creating advice [message #61706 is a reply to message #61682] Mon, 06 February 2006 12:53 Go to previous message
Matt Chapman is currently offline Matt ChapmanFriend
This looks like the sort of error caused by a mismatch between AJDT and
Eclipse versions. If you go to Help > About Eclipse SDK, what build id do
you see - is it I20050627-1435? Next click on the AJ feature icon on that
dialog, then press "Plug-in Details". Expand the Version column of that
table and look at the last field of the version number - is it
20051220093604 for all plugins? Have you ever installed any other version
of AJDT into the same eclipse installation? If so, it could be picking up
that other version.
Matt.
> solution.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
Re: Error creating advice [message #592121 is a reply to message #61682] Mon, 06 February 2006 12:53 Go to previous message
that other version.
Matt.
> solution.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
Previous Topic:Error creating advice
Next Topic:AspectJ DOM
Current Time: Sat Dec 21 11:52:20 GMT 2024
Powered by FUDForum. Page generated in 0.03529 seconds
