Re: XPand: String concatination [message #61659 is a reply to message #61611] |
Mon, 25 May 2009 19:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Change the order of the UML and EMF metamodel contributors in the
project settings. UML must come first when using both, otherwise EMF
wins and maps the String primitive type to an EClassType, but the UML
typesystem recognizes the primitives and maps them to the builtin
typesystem.
~Karsten
~Karsten
On 25.05.09 12:40, Jan Koehnlein wrote:
> Hmm, looks like a bug in the tooling around the UML typesystem. I filed
> a bug for that
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=277666
> I hope we can fix it before the Galileo release.
> Regards
> Jan
> Usul schrieb:
>> In the XPand-Editor, I get an error when trying to concatenate a
>> string with a model-value. Here is my template:
>> «IMPORT otml»
>> «IMPORT uml»
>> «DEFINE main FOR Model»
>> «EXPAND showpackages FOREACH this.nestedPackage» «ENDDEFINE»
>> «DEFINE showpackages FOR Package»
>> «FILE "\\" + this.name + "foo"» <---- ERROR HERE
>> test
>> «ENDFILE»
>> «ENDDEFINE»
>> I marked the line, where the error occurs. The problem is: "Couldn't
>> find operation '+(uml::String)' for type 'String'". I tried explizit
>> casting, but it did not work: "«FILE "\\" + (String)this.name +
>> "foo"»". But it would work like that: "«FILE "\\" +
>> (String)this.name»". While this does not work: "«FILE "\\" + this.name»".
>> And another (for me) interesting fact: If I use the template by using
>> Xpand programmaticly, it works just fine. So why does the editor (and
>> problem-view) have problems?
>> Thank you for any help
Need professional support for Xtext, EMF, Eclipse IDE?
Go to: http://devhub.karakun.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
Re: XPand: String concatination [message #61705 is a reply to message #61659] |
Mon, 25 May 2009 22:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
No real name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=skobilke%40gmx.de) Messages: 61 Registered: July 2009 |
Member |
Hi Karsten,
> typesystem.
> ~Karsten
In "Project"->"Properties"->"Xtend/Xpand" I checked both "UML2 profiles"
and "EMF Metamodels" and put "UML2 profiles" up to first place. The
example I posted works then. But this does not work:
«IMPORT uml» <---- ERROR 1
«IMPORT otml»
«DEFINE createFile(String packageName) FOR TeamClass»
«FILE packageName + "\\" + this.name + ".java"» <---- ERROR 2
Team: «this.name»
«ENDFILE»
«ENDDEFINE»
«DEFINE createFile(String packageName) FOR PackageableElement»
«FILE packageName + "\\" + this.name + ".txt"» *
Else: «this.name»
«ENDFILE»
«ENDDEFINE»
Error 1: "Couldn't find operation '+(uml::String)' for type 'String'"
Error 2: "String expected!"
That is pretty strange, because only one (seemingly random) line is
affected. Without your solution, the line marked with "*" also had Error
1 (that error diesappeared).
>> a bug for that
>> Regards
>> Jan
>>> «IMPORT otml»
>>> «IMPORT uml»
>>> «FILE "\" + this.name + "foo"» <---- ERROR HERE
>>> test
>>> «ENDFILE»
>>> «ENDDEFINE»
>>> casting, but it did not work: "«FILE "\" + (String)this.name +
>>> "foo"»". But it would work like that: "«FILE "\" +
>>> (String)this.name»". While this does not work: "«FILE "\" + this.name»".
FUDForum. Page generated in 0.03172 seconds
