Home » Language IDEs » Java Development Tools (JDT) » Profiler Plugin and Rhino Problem
Profiler Plugin and Rhino Problem [message #61580] Thu, 19 June 2003 08:52 Go to next message
test is currently offline testFriend
Member
I get the following exception when I try to profile my application using the
Profiler Plugin 5.25.
java.lang.VerifyError: (class: org/mozilla/javascript/DToA, method:
JS_dtobasestr signature: (ID)Ljava/lang/String;) Cannot load return address
from register 30
I am using JDK 1.4.1_02 and my application utilises the mozilla rhino
javascript engine version 1.5r4.1
I only get this problem when profiling, running and debugging the
application works fine. I have used the same classpath for profiling and
normal operation.
Any ideas?
Many Thanks
Dave
Re: Profiler Plugin and Rhino Problem [message #61654 is a reply to message #61580] Thu, 19 June 2003 10:18 Go to previous messageGo to next message
> from register 30
> normal operation.
> Any ideas?
Most probably this is problem in profiler instrumentation.
Can you send me minimal test application?
Also try latest version of profiler.
SY, Konstantin.
Re: Profiler Plugin and Rhino Problem [message #61841 is a reply to message #61580] Thu, 19 June 2003 14:31 Go to previous message
> from register 30
Ok, I already have test case from another user.
Can you please contact me in e-mail, so I will give you fixed jar for
testing?
SY, Konstantin.
Previous Topic:Junit output
Next Topic:Using Eclipse (JDT) in a compiler class
Current Time: Thu Jan 02 19:18:57 GMT 2025
Powered by FUDForum. Page generated in 0.05790 seconds
