Re: Profiler Plugin and Rhino Problem [message #61654 is a reply to message #61580] |
Thu, 19 June 2003 10:18 |
Originally posted by: scheglov_ke.nlmk.ru
Dave <test@test.com> wrote:
> I get the following exception when I try to profile my application using the
> Profiler Plugin 5.25.
> java.lang.VerifyError: (class: org/mozilla/javascript/DToA, method:
> JS_dtobasestr signature: (ID)Ljava/lang/String;) Cannot load return address
> from register 30
> I am using JDK 1.4.1_02 and my application utilises the mozilla rhino
> javascript engine version 1.5r4.1
> I only get this problem when profiling, running and debugging the
> application works fine. I have used the same classpath for profiling and
> normal operation.
> Any ideas?
Most probably this is problem in profiler instrumentation.
Can you send me minimal test application?
Also try latest version of profiler.
SY, Konstantin.
Re: Profiler Plugin and Rhino Problem [message #61841 is a reply to message #61580] |
Thu, 19 June 2003 14:31 |
> from register 30
Ok, I already have test case from another user.
Can you please contact me in e-mail, so I will give you fixed jar for
testing?
SY, Konstantin.
FUDForum. Page generated in 0.03342 seconds
