Re: plans to extend platform model to support peripherals [message #5480 is a reply to message #5473] |
Tue, 21 July 2009 19:34 |
Chris Ring Messages: 16 Registered: July 2009 Location: Santa Barbara, CA |
Junior Member |
dave russo wrote:
> The RTSC team is planning to extend the platform model to support device
> peripherals. This should make it easier to:
> o produce "portable" board support packages
> o ensure peripherals are consistently used among independent packages
> For more information see the wiki topic
> http://wiki.eclipse.org/DSDP/RTSC_-_xdc.platform.ICpuDataShe et.
> Comments and suggestions are welcome.
This may be an opportunity to also add EDMA3- and HWA-related properties
to the platform. Then some of our resource managers (e.g. DMAN3,
EDMA3LLD, RMAN, etc) could 'auto-assign' base addrs, etc rather than
rely on the user cfg script?
I'm also wondering if, on a multi-core device, the DSP could/should be a
'peripheral' of the GPP. Codec Engine has some hard-coded uglies in our
ARM-side cfg where, given a Platform, we'd like to know more details
about the DSP (e.g. is it a C64P or C674?) - and I'm not sure there's a
reliable way to determine that across all devices(?).
Chris
FUDForum. Page generated in 0.02932 seconds
