Home » Archived » XML Schema Definition (XSD) » How to get elements from included schema?
How to get elements from included schema? [message #61412] |
Fri, 10 June 2005 09:21 |
Originally posted by: ksrki.uns.ns.ac.yu
I have two schemas (A and B) and schema A includes contents from the
schema B via <xsd:include> property of XML Schema rec. It (schema A)
also references some of the elements of the schema B. When I traverse
schema A I'm not able to get any info about the type definition of the
referenced elements, ie. element.getTypeDefinition() returns null.
Is there any cure to this situation?
Thanks for help,
Srdjan Komazec
Re: How to get elements from included schema? [message #61436 is a reply to message #61412] |
Fri, 10 June 2005 10:42 |
Srdjan,
Maybe you need to do
element.getResolvedElementDeclaration().getTypeDefinition() because you
have traversed to an element ref?
Srdjan Komazec wrote:
> Thanks for help,
> Srdjan Komazec
Re: How to get elements from included schema? [message #61457 is a reply to message #61436] |
Fri, 10 June 2005 12:47 |
Thanks on fast replay.
Unfortunatelly, that is not an issue because I have called
getResolvedElementDeclaration() for all XSDElementDeclaration instances
before any other method of the class to be sure that I have concrete
element (this method returns the same instance if it is not element ref).
I'm wondering if there is any special treatment for those elements that
came from another schema (included by <xsd:include> or imported by
<xsd:import>)?
Thanks in adavnced!
Ed Merks wrote:
> Srdjan,
>> Thanks for help,
>> Srdjan Komazec
Re: How to get elements from included schema? [message #61480 is a reply to message #61457] |
Fri, 10 June 2005 13:31 |
Srdjan,
As far as I know, the only way the type could be null is if the element
reference is an unresolved one, i.e., if element.getContainer() ==
null. Have you validated the schema (XSDMainTest in
org.eclipse.xsd.test shows how and the test directory there has scripts
you can use for command line validation) or tried opening the schema in
the Sample XML Schema Editor to check for problems? It sounds likely
that your imports or includes aren't resolving correctly.
My answers can be much more concrete if you show exactly what you are
doing (in terms of code) and what instances you are working with...
> instances before any other method of the class to be sure that I have
> concrete element (this method returns the same instance if it is not
> element ref).
> that came from another schema (included by <xsd:include> or imported
> by <xsd:import>)?
> Thanks in adavnced!
> Ed Merks wrote:
>> Srdjan,
>> you have traversed to an element ref?
>>> Hi,
>>> traverse schema A I'm not able to get any info about the type
>>> definition of the referenced elements, ie.
>>> Thanks for help,
>>> Srdjan Komazec
Re: How to get elements from included schema? [message #61503 is a reply to message #61480] |
Fri, 10 June 2005 14:13 |
--------------050703010505030806000701
Content-Type: text/plain; charset=UTF-8; format=flowed
Ed, thanks for fast replay again.
Both schema instances were created with XMLSpy. XML Schema editor
doesn't make any problem either.
I'm sending these two schema files (person.xsd and class.xsd). I'm also
sending code (TestInclude2.java) that is designed to show my problem
(and XSDSearch class which is utility class).
Hope to hear something soon.
Srdjan Komazec
Ed Merks wrote:
> Srdjan,
>> element ref).
>> by <xsd:import>)?
>> Thanks in adavnced!
>> Ed Merks wrote:
>>> Srdjan,
>>>> Hi,
>>>> Thanks for help,
>>>> Srdjan Komazec
Content-Type: text/xml;
name="class.xsd"
Content-Disposition: inline;
filename="class.xsd"
<xsd:schema xmlns:prob="http://ccd.ns.ac.yu/probaInclude" xmlns:xsd="http://www.w3.org/2001/XMLSchema" targetNamespace="http://ccd.ns.ac.yu/probaInclude" elementFormDefault="qualified" attributeFormDefault="unqualified">
<xsd:include schemaLocation="person.xsd"/>
<xsd:element name="class">
<xsd:annotation>
<xsd:documentation>Comment describing your root element</xsd:documentation>
</xsd:annotation>
<xsd:complexType>
<xsd:sequence maxOccurs="unbounded">
<xsd:element ref="prob:Person"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
name="person.xsd"
filename="person.xsd"
<xsd:element name="Person">
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
<xsd:sequence>
<xsd:element name="Name" type="xsd:string"/>
<xsd:element name="Age" type="xsd:integer"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
Content-Type: text/x-java;
name="TestInclude2.java"
filename="TestInclude2.java"
package com.ccd.xsd.test;
import java.util.Iterator;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.xsd.XSDComplexTypeContent;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDElementDeclaration;
import org.eclipse.xsd.XSDModelGroup;
import org.eclipse.xsd.XSDParticle;
import org.eclipse.xsd.XSDParticleContent;
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.util.XSDResourceFactoryImpl;
import org.eclipse.xsd.util.XSDResourceImpl;
import com.ccd.xsd.util.resolve.search.XSDSearch;
* Class:TestInclude
* Date:Jun 8, 2005 11:00:05 AM
* Description:
* @author Srdjan Komazec FTN - Novi Sad <a href="mailto:ksrki@uns.ns.ac.yu">ksrki@uns.ns.ac.yu</a>
* @version 1.0
public class TestInclude2 {
public TestInclude2(){
String schemaURL = "src/com/ccd/xsd/test/class.xsd";
XSDSchema schema = null;
Object component = null;
XSDElementDeclaration rootElement = null, childElement = null;
XSDComplexTypeDefinition complexTypeDefinition = null;
XSDComplexTypeContent complexTypeContent = null;
XSDParticleContent particleContent = null;
//Loading the schema
try {
schema = loadSchemaUsingResourceSet(schemaURL);
} catch (Exception e) {
e.printStackTrace();
//Browsing the schema content and searching for Element Declarations
Iterator iter = schema.getContents().iterator();
while (iter.hasNext()){
component = iter.next();
if (component instanceof XSDElementDeclaration){
//Found root element decalation
rootElement = (XSDElementDeclaration)component;
break;
//Taking type definition for class element
complexTypeDefinition = (XSDComplexTypeDefinition)rootElement.getTypeDefinition();
//Content of this complex type definition
complexTypeContent = complexTypeDefinition.getContent();
//Because I know that class sequence of person element refrences comprise class element I have created an
//iterator to what this sequence consists of (Person elemenet references)
iter = ((XSDModelGroup)((XSDParticle)complexTypeContent).getContent ()).getContents().iterator();
while(iter.hasNext()){
particleContent = ((XSDParticle)iter.next()).getContent();
if (particleContent instanceof XSDElementDeclaration){
//Here is our Person element reference (from included schema)
childElement = (XSDElementDeclaration)particleContent;
//The reference needs to be resolved
childElement = XSDSearch.getElementByReference(childElement);
//THERE IS NO TYPE DEFINITION FOR THIS ELEMENT? HOW TO GET ONE?
if (childElement.getTypeDefinition() == null)
System.out.println("No type definition for Person element which is included from Person Schema!");
new TestInclude2();
private XSDSchema loadSchemaUsingResourceSet(String schemaURL) throws Exception{
XSDSchema returnSchema = null;
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd", new XSDResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION, Boolean.TRUE);
XSDResourceImpl xsdSchemaResource = (XSDResourceImpl)resourceSet.getResource(URI.createURI(schem aURL), true);
xsdSchemaResource.load(null);
for (Iterator resources = resourceSet.getResources().iterator(); resources.hasNext(); /* no-op */){
Resource resource = (Resource)resources.next();
if (resource instanceof XSDResourceImpl){
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
returnSchema = xsdResource.getSchema();
return returnSchema;
System.err.println("loadSchemaUsingResourceSet(" + schemaURL + ") did not contain any schemas!");
return null;
name="XSDSearch.java"
filename="XSDSearch.java"
* Created on May 9, 2005
package com.ccd.xsd.util.resolve.search;
import org.eclipse.xsd.XSDAttributeDeclaration;
* @author srdjan
* Klasa XSDSearch sadrzi metode koje pomazu u pronalazenju odredjenih segmenata XML Schema dokumenata
* (elemenata, atributa, definicija tipova i sl).
public class XSDSearch {
* Finding root element. If root element isn't finded the null is returned
public static XSDElementDeclaration rootElementDeclarationFinder(XSDSchema schema, String localName){
Object tempXSDComponent = null;
Iterator rootElementsOfTheSchema = schema.getContents().iterator();
while(rootElementsOfTheSchema.hasNext()){
tempXSDComponent = rootElementsOfTheSchema.next();
//Ukoliko je u pitanju deklaracija elementa
if (tempXSDComponent instanceof XSDElementDeclaration)
//Ukoliko se ime posmatranog elementa poklapa sa imenom koje se trazi
if (((XSDElementDeclaration)tempXSDComponent).getName().equals( localName))
break;
return (XSDElementDeclaration)tempXSDComponent;
public static XSDElementDeclaration getElementByReference(XSDElementDeclaration elementDeclaration) {
XSDElementDeclaration targetElementDeclaration = elementDeclaration;
//Ako je u pitanju referenca tada treba da vratimo deklaraciju elementa na koju ona referise
if (elementDeclaration.isElementDeclarationReference())
targetElementDeclaration = elementDeclaration.getResolvedElementDeclaration();
return targetElementDeclaration;
public static XSDAttributeDeclaration getAttributeByReference(XSDAttributeDeclaration attributeDeclaration) {
XSDAttributeDeclaration targetAttributeDeclaration = attributeDeclaration;
if (attributeDeclaration.isAttributeDeclarationReference())
targetAttributeDeclaration = attributeDeclaration.getResolvedAttributeDeclaration();
return targetAttributeDeclaration;
--------------050703010505030806000701--
Re: How to get elements from included schema? [message #61548 is a reply to message #61503] |
Fri, 10 June 2005 15:55 |
--------------040709040906060805050600
Sridjan,
I haven't run the test code, but I'm quite sure the problem is that you
are loading the root schema with a relative URI rather than an absolute
URI and relative schemaLocations can only be resolved against an
absolute URI. In the XSDMainTest you'll see code like this which
ensures that if a file path is passed that it is converted to a file:
URI with an absolute path:
URI uri;
File file = new File(xsdFile);
if (file.isFile())
uri = URI.createFileURI(file.getCanonicalFile().toString());
else
uri = URI.createURI(xsdFile);
I think you need to do the same.
The bottom line is that if the URI you use to load the schema is not
absolute, i.e., doesn't start with <scheme>:, relative includes and
imports won't resolve and won't work...
> also sending code (TestInclude2.java) that is designed to show my
> problem (and XSDSearch class which is utility class).
> Best regards,
> Srdjan Komazec
> Ed Merks wrote:
>> Srdjan,
>> element reference is an unresolved one, i.e., if
>> element.getContainer() == null. Have you validated the schema
>> (XSDMainTest in org.eclipse.xsd.test shows how and the test directory
>> there has scripts you can use for command line validation) or tried
>> opening the schema in the Sample XML Schema Editor to check for
>> problems? It sounds likely that your imports or includes aren't
>>> have concrete element (this method returns the same instance if it
>>> elements that came from another schema (included by <xsd:include> or
>>> imported by <xsd:import>)?
>>> Thanks in adavnced!
>>> Ed Merks wrote:
>>>> Srdjan,
>>>>> Hi,
>>>>> the schema B via <xsd:include> property of XML Schema rec. It
>>>>> (schema A) also references some of the elements of the schema B.
>>>>> When I traverse schema A I'm not able to get any info about the
>>>>> type definition of the referenced elements, ie.
>>>>> Thanks for help,
>>>>> Srdjan Komazec
><?xml version="1.0" encoding="UTF-8"?>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:complexType>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
></xsd:schema>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
></xsd:schema>
> * Class:TestInclude
> * Description:
> * @version 1.0
> try {
> break;
> public static void main(String[] args) {
> new TestInclude2();
> return null;
> * @author srdjan
> break;
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Sridjan,<br>
<br>
URI with an absolute path:<br>
<blockquote> URI uri;<br>
File file = new File(xsdFile);<br>
if (file.isFile())<br>
{<br>
uri = URI.createFileURI(file.getCanonicalFile().toString());<br>
}<br>
else<br>
{<br>
uri = URI.createURI(xsdFile);<br>
}<br>
</blockquote>
I think you need to do the same. <br>
<br>
and imports won't resolve and won't work...<br>
<br>
<br>
<blockquote cite="midd8c75k$7c2$1@news.eclipse.org" type="cite">Ed,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Srdjan Komazec
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Srdjan,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite"><br>
<br>
<br>
ref).
<br>
<br>
<br>
<br>
Thanks in adavnced!
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi,
<br>
<br>
A) also references some of the elements of the schema B. When I
definition of the referenced elements, ie. element.getTypeDefinition()
returns null.
<br>
<br>
<br>
<br>
Thanks for help,
<br>
Srdjan Komazec
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<pre wrap="">
<hr size="4" width="90%">
<xsd:schema xmlns:prob=<a class="moz-txt-link-rfc2396E" href="http://ccd.ns.ac.yu/probaInclude">"http://ccd.ns.ac.yu/probaInclude"</a> xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a> targetNamespace=<a class="moz-txt-link-rfc2396E" href="http://ccd.ns.ac.yu/probaInclude">"http://ccd.ns.ac.yu/probaInclude"</a> elementFormDefault="qualified" attributeFormDefault="unqualified">
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
</pre>
<pre wrap="">
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
</pre>
<pre wrap="">
* Class:TestInclude
* Description:
* @author Srdjan Komazec FTN - Novi Sad <a href=<a class="moz-txt-link-rfc2396E" href="mailto:ksrki@uns.ns.ac.yu">"mailto:ksrki@uns.ns.ac.yu"</a>><a class="moz-txt-link-abbreviated" href="mailto:ksrki@uns.ns.ac.yu">ksrki@uns.ns.ac.yu</a></a>
* @version 1.0
try {
break;
new TestInclude2();
return null;
</pre>
<pre wrap="">
* @author srdjan
break;
</pre>
</blockquote>
<br>
</body>
</html>
--------------040709040906060805050600--
Re: How to get elements from included schema? [message #595596 is a reply to message #61412] |
Ed Merks Messages: 33171 Registered: July 2009 |
Srdjan,
> Thanks for help,
> Srdjan Komazec
Ed Merks
Re: How to get elements from included schema? [message #595609 is a reply to message #61436] |
<xsd:import>)?
Thanks in adavnced!
Ed Merks wrote:
> Srdjan,
>> Thanks for help,
>> Srdjan Komazec
Re: How to get elements from included schema? [message #595614 is a reply to message #61457] |
Srdjan,
> element ref).
> by <xsd:import>)?
> Thanks in adavnced!
> Ed Merks wrote:
>> Srdjan,
>>> Hi,
>>> Thanks for help,
>>> Srdjan Komazec
Ed Merks
Re: How to get elements from included schema? [message #595623 is a reply to message #61480] |
Srdjan Komazec
Ed Merks wrote:
> Srdjan,
>> element ref).
>> by <xsd:import>)?
>> Thanks in adavnced!
>> Ed Merks wrote:
>>> Srdjan,
>>>> Hi,
>>>> Thanks for help,
>>>> Srdjan Komazec
name="class.xsd"
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
name="person.xsd"
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
* Class:TestInclude
* Description:
* @version 1.0
try {
break;
new TestInclude2();
return null;
* @author srdjan
break;
Re: How to get elements from included schema? [message #595633 is a reply to message #61503] |
Sridjan,
URI uri;
if (file.isFile())
else
> Best regards,
> Srdjan Komazec
> Ed Merks wrote:
>> Srdjan,
>>> Thanks in adavnced!
>>> Ed Merks wrote:
>>>> Srdjan,
>>>>> Hi,
>>>>> Thanks for help,
>>>>> Srdjan Komazec
> <xsd:annotation>
> </xsd:annotation>
> <xsd:complexType>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
></xsd:schema>
> <xsd:annotation>
> </xsd:annotation>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
></xsd:schema>
> * Class:TestInclude
> * Description:
> * @version 1.0
> try {
> break;
> new TestInclude2();
> return null;
> * @author srdjan
> break;
<html>
<head>
</head>
Sridjan,<br>
<br>
{<br>
}<br>
else<br>
{<br>
}<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Srdjan Komazec
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
ref).
<br>
<br>
<br>
<br>
Thanks in adavnced!
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
returns null.
<br>
<br>
<br>
<br>
Thanks for help,
<br>
Srdjan Komazec
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<pre wrap="">
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
</pre>
<pre wrap="">
<xsd:annotation>
</xsd:annotation>
<xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
</pre>
<pre wrap="">
* Class:TestInclude
* Description:
* @version 1.0
try {
break;
new TestInclude2();
return null;
</pre>
<pre wrap="">
* @author srdjan
break;
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Current Time: Wed Jul 03 01:33:07 GMT 2024
Powered by FUDForum. Page generated in 0.04759 seconds
