Home » Language IDEs » Java Development Tools (JDT) » Autocomplete Javadoc comments ?
Autocomplete Javadoc comments ? [message #61361] Wed, 18 June 2003 18:22 Go to next message
Originally posted by: cybe.asshole.com
is there a plugin or command to auto-complete Javadocs comments for
methods in a java class , like in Jbuilder, Netbeans, Idea ?
thanks !
Re: Autocomplete Javadoc comments ? [message #61433 is a reply to message #61361] Thu, 19 June 2003 02:55 Go to previous messageGo to next message
write the method signature
public void setSomething(Object something){
write the beginning of the JavaDoc '/**' before the methods signature
and press CTRL + Enter and you will get the JavaDoc (the blank line is a
little bit annoying)
* Method setSomething()
* @param something
This works also for return types, throws-clauses.
Michael
Am Wed, 18 Jun 2003 19:22:13 -0300 hat cyber <cybe@asshole.com>
geschrieben:
> thanks !
Dipl. Ing. Michael Täge
Bauschlotterstr. 36
75177 Pforzheim
Fon: 07231 51278
Mobil: 0171 8067809
m-taege@t-online.de
Re: Autocomplete Javadoc comments ? [message #61724 is a reply to message #61433] Thu, 19 June 2003 09:06 Go to previous messageGo to next message
There should not be a blank line. Did you check Preferences > Java >
Code Generation -> Code and Comments > Method - Comment if you didn't
add a new line yourself?
Martin
Michael Taege wrote:
> Hello,
> * @param something
> Michael
> geschrieben:
>> thanks !
Re: Autocomplete Javadoc comments ? [message #61748 is a reply to message #61724] Thu, 19 June 2003 09:15 Go to previous messageGo to next message
Hello Martin,
I don't think so. Here's my entry from the preferences:
* Method ${enclosing_method}()
* ${tags}
Before I'm pressing the CTRL+Enter command the cursor is directly after the
last '*' from the start of the JavaDoc that's correct too, isn't it?
Michael
Am Thu, 19 Jun 2003 15:06:49 +0200 hat Martin Aeschlimann
<martin_aeschlimann@ch.ibm.com> geschrieben:
> There should not be a blank line. Did you check Preferences > Java > Code
> Generation -> Code and Comments > Method - Comment if you didn't add a
> new line yourself?
> Martin
>> Hello,
>> * @param something
>> Michael
>> geschrieben:
>>> thanks !
Bauschlotterstr. 36
75177 Pforzheim
Fon: 07231 51278
Mobil: 0171 8067809
m-taege@t-online.de
Re: Autocomplete Javadoc comments ? [message #61772 is a reply to message #61748] Thu, 19 June 2003 09:37 Go to previous messageGo to next message
oha, context-menu->Source->Add JavaDoc Comment works fine.
I've also tried to bound 'Add JavaDoc Comment' to CTRL+J (originally
Texteditor: Incremental Find),
which also works fine. But not using CTRL+Enter.
Michael
Am Thu, 19 Jun 2003 15:15:37 +0200 hat Michael Taege <m-taege@t-online.de>
geschrieben:
> Hello Martin,
> * ${tags}
> the last '*' from the start of the JavaDoc that's correct too, isn't it?
> Michael
>> Martin
>>> Hello,
>>> a little bit annoying)
>>> * @param something
>>> Michael
>>> geschrieben:
>>>> thanks !
Bauschlotterstr. 36
75177 Pforzheim
Fon: 07231 51278
Mobil: 0171 8067809
m-taege@t-online.de
Re: Autocomplete Javadoc comments ? [message #68081 is a reply to message #61772] Thu, 26 June 2003 09:19 Go to previous message
A normal enter should be enough. I can't reproduce this with CTRL + Enter
/**< enter here
> Michael
> <m-taege@t-online.de> geschrieben:
>> Hello Martin,
>> * ${tags}
>> after the last '*' from the start of the JavaDoc that's correct too,
>> isn't it?
>> Michael
>>> Martin
>>>> Hello,
>>>> is a little bit annoying)
>>>> * @param something
>>>> Michael
>>>> geschrieben:
>>>>> thanks !
Previous Topic:Indenting simple if statements
Next Topic:Launch Configuration - Debug
Current Time: Sat Oct 25 21:07:43 EDT 2025
Powered by FUDForum. Page generated in 0.40342 seconds
