Home » Archived » Memory Analyzer (MAT) » Help understanding Heap Analysis
Help understanding Heap Analysis [message #5464] |
Thu, 16 October 2008 12:38  |
Hi everybody,
I'm testing a web application(Struts 2.0, Spring 2.0, Hibernate 3.0, JDK
1.5.0_15, Tomcat 5) which has some potential memory related problems.
Initially the application was giving "java.lang.OutOfMemoryError: PermGen
space".
The PermGen settings were default i.e. Min:16M & Max:64M
I tried and load test the application with JMeter and again reproduced the
same "java.lang.OutOfMemoryError: PermGen space".
After that I changed the PermGen settings to Min:32M & Max:256M
After this there were no "java.lang.OutOfMemoryError: PermGen space"
issues..
Next I chose "Eclipse Memory Analyzer" to analyze the Heap dumps.
I also heard of "Leaking ClassLoaders". I tried identifying those too but
didnt succeed may be I am new to "Eclipse Memory Analyzer".
The strategy that I'm thinking goes like this:
(1). First I will identify some important/potential use cases that might
consume more memory(say 30-50 use cases)
(2). Next after performing that use case in the application I will be
taking the Heap Dump using jmap using:
jmap -heap:format=b <pid>
(3). For each of the identified use cases I'll be analyzing the Heap Dump
and accordingly collecting statistics.
This way I guess I'll be able to identify the potential memory leaks in
the application....
IS MY STRATEGY CORRECT?
IS THERE ANY OTHER WAY OF SOLVING THE POTENTIAL MEMORY RELATED PROBLEMS IN
MY APPLICATION?
Please give some suggestions or alternatives as I'm new in using Eclipse
Memory Analyzer.
Thanks & Regards,
Nirmal
Re: Help understanding Heap Analysis [message #5485 is a reply to message #5464] |
Fri, 17 October 2008 03:59   |
The "Leaking Classloaders" is part of the SAP NetWeaver extensions for MAT
and recognizes left-over classloaders in heap dumps from the SAP
application server only. Recently I blogged about it at the SAP Developers
Network site: https://www.sdn.sap.com/irj/sdn/weblogs?blog=/pub/wlg/11129
What Memory Analyzer is very good at - it shows you where most of the
memory is kept - the biggest objects, classes, etc...
If you have a memory leak and there is enough space for it to occupy, then
it will be very easy to see it with MAT. As example - assume you have an
application which normaly runs with 500 - 700 mb (after full GC). If you
give the VM -Xmx800m, you will probably not be able to see the problem
once it occurs. But if you give the VM 1500Mb, then the leak will "eat"
about 700-800 Mb before the system goes into OutOfMemoryError, and you can
see the big problem at a glance with MAT afterwards.
However, what you want to do is different (as far as I understood). You
want to proactively search for leaks, without waiting for them to grow too
much. And this will be difficult to analyze with only one snapshot.
What you could do for every scenario is:
1) warm the system up - run the whole scenario once, so that all necessary
caches get filled, all needed initialization is done. Take a heap dump then
2) without restarting, execute the same scenario again. At the end take
another heap dump.
If the warm up was proper, then I expect that at the end of the second
test the heap should be at the same level as at the end of the first test.
You can just compare both dumps. Unfortunately, for now we offer a very
limited compare functionality - only on class histogram level. I recommend
you that you compare the dominator tree, grouped by class or package. You
can export the data from both dumps and compare (not within the tool).
Thus you should be able to see if some classes / packages got bigger after
the second test.
What do you think about the suggestion? I'd be happy to hear from you,
when you finish with the tests, if this helped with the analysis or not.
Krum
Re: Help understanding Heap Analysis [message #5495 is a reply to message #5485] |
Fri, 17 October 2008 05:33   |
First of all thanks a lot for showing me the right direction.
MAT and recognizes left-over classloaders in heap dumps from the SAP
Is that mean that I can't identify whether my application has some
"Leaking Classloaders" or not using "Eclipse Memory Analyzer" ? ? ?
I'm asking this thing beacuse earlier our application was giving
"java.lang.OutOfMemory : PermGen space" error.
Well, I'll follow your guidelines:
another heap dump. If the warm up was proper, then I expect that at the
end of the second test the heap should be at the same level as at the end
of the first test. You can just compare both dumps. Unfortunately, for now
we offer a very limited compare functionality - only on class histogram
level. I recommend you that you compare the dominator tree, grouped by
class or package. You can export the data from both dumps and compare (not
within the tool).
the second test.
I am sure I'll come up with good results.
Thanks & Regards,
Nirmal
Re: Help understanding Heap Analysis [message #5680 is a reply to message #5485] |
Sat, 18 October 2008 06:43   |
Krum Tsvetkov wrote:
> another heap dump.
> the second test.
> Krum
Hi Krum,
I am using JMeter. I recorded a long conversation covering almost every
operation in the application. Then I ran that conversation with 50
concurrent users in JMeter thus creating a good load on the server.
At the completion of this conversation of 50 users I took the Heap
dump(named it "firstHeap50Users").
Next I stoppped all the threads for 50 users in the JMeter and again
followed the same procedure i.e ran the conversation with 50 concurrent
users in JMeter.
Again took the heap dump named it "secondHeap50Users".
This process I repeated 4 times and hence I am having 4 dumps:
1.)"firstHeap50Users" 64.7 MB
2.)"secondHeap50Users" 101 MB
3.)"thirdHeap50Users" 96.1 MB
4.)"fourthHeap50Users" 111 MB
I then analyzed the 4 heap dumps but didnt find any success as everytime
the reports are similar and there is'nt any case like you said to find:
> the second test.
Actually my web application uses 2 more applications i.e on the single
instance of Tomcat there are 3 web applications running at a time.
Tomcat has the following web apps running:
1.crystal
2.crystal_mny
3.pretups(This is my web application that use the first two web apps)
Hence here are 3 "WebappClassLoader(one for each web application)" shown
in the Heap Analysis Report.
I have even collected reports separately for the 4 heap dumps in an excel
file.
I can send you that so that you can help me out where exactly I should
analyze.....
Thanks & Regards
Nirmal
Current Time: Fri Apr 25 01:27:44 EDT 2025
Powered by FUDForum. Page generated in 0.03532 seconds
