Home » Eclipse Projects » Remote Application Platform (RAP) » Problem during starting Bundle
Problem during starting Bundle [message #61339] |
Wed, 21 November 2007 07:38 |
Steffen Peil Messages: 6 Registered: July 2009 |
Junior Member |
That's my new Problem ! Why i can't start the Bundle com.we4it.rap ?
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.ui;
bundle-version="0.0.0"
The Bundle is Installed but i can't start that !
Greetz
Her is the LOG-File:
ss
08:26:03,278 INFO [STDOUT] Framework is launched.
08:26:03,278 INFO [STDOUT] id
08:26:03,293 INFO [STDOUT] State Bundle
08:26:03,293 INFO [STDOUT] 0 ACTIVE
system.bundle_3.2.2.R32x_v20070118
08:26:03,293 INFO [STDOUT] Fragments=
08:26:03,293 INFO [STDOUT] 28
08:26:03,293 INFO [STDOUT] 1 ACTIVE
org.eclipse.core.commands_3.2.0.I20060605-1400
08:26:03,293 INFO [STDOUT] 2 ACTIVE
org.eclipse.core.contenttype_3.2.0.v20060603
08:26:03,293 INFO [STDOUT] 3 ACTIVE
org.eclipse.core.jobs_3.2.0.v20060603
08:26:03,293 INFO [STDOUT] 4 ACTIVE
org.eclipse.core.runtime_3.2.0.v20060603
08:26:03,293 INFO [STDOUT] 5 ACTIVE
org.eclipse.equinox.common_3.2.0.v20060603
08:26:03,293 INFO [STDOUT] 6 ACTIVE
org.eclipse.equinox.http.registry_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 7 ACTIVE
org.eclipse.equinox.http.servletbridge_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 8 ACTIVE
org.eclipse.equinox.http.servlet_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 9 ACTIVE
org.eclipse.equinox.preferences_3.2.1.R32x_v20060717
08:26:03,293 INFO [STDOUT] 10 ACTIVE
org.eclipse.equinox.registry_3.2.1.R32x_v20060814
08:26:03,293 INFO [STDOUT] 11 ACTIVE
org.eclipse.osgi.services_3.1.100.v20060601
08:26:03,293 INFO [STDOUT] 13 ACTIVE
org.eclipse.rap.jface_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 14 ACTIVE
org.eclipse.rap.rwt_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 15 ACTIVE
org.eclipse.rap.ui.workbench_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 16 ACTIVE
org.eclipse.rap.w4t_1.0.0.200705071244
08:26:03,293 INFO [STDOUT] 17 ACTIVE
org.eclipse.update.configurator_3.2.2.R32x_v20070111
08:26:03,293 INFO [STDOUT] 28 RESOLVED
org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
08:26:03,293 INFO [STDOUT] Master=0
08:26:03,293 INFO [STDOUT] 37 INSTALLED com.we4it.rap_1.0.1
osgi>
start 37
08:26:16,840 INFO [STDOUT] org.osgi.framework.BundleException: The bundle
could not be resolved. Reason: Missing Constraint: Require-Bundle:
org.eclipse.rap.ui; bundle-version="0.0.0"
08:26:16,840 INFO [STDOUT] at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:239)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:585)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
08:26:16,840 INFO [STDOUT] at java.lang.Thread.run(Thread.java:595)
Re: Problem during starting Bundle [message #61365 is a reply to message #61339] |
Wed, 21 November 2007 07:47 |
Valer Roman Messages: 36 Registered: July 2009 |
Member |
> Greetz
> ss
> 08:26:03,293 INFO [STDOUT] osgi> start 37
> bundle could not be resolved. Reason: Missing Constraint:
> Require-Bundle: org.eclipse.rap.ui; bundle-version="0.0.0"
In your active bundles I can not see org.eclipse.rap.ui bundle, I can
only see org.eclipse.rap.ui.workbench. I think u will bve fine adding
org.eclipse.rap.ui bundle.
Val
Re: Problem during starting Bundle [message #61389 is a reply to message #61365] |
Wed, 21 November 2007 08:20 |
Junior Member |
Thank's for that. Now the Bundle ist ACTIVE, but why i can't start that on
http://localhost:8080/we4it/start
The deployed WAR File called "we4it.war" and com.we4it.rap_1.0.1 have an
EntryPoint called "start". Any Idea?
Greetz
HTTP Status 404 - ProxyServlet: /we4it/start
type Status report
message ProxyServlet: /rapdemo/start
description The requested resource (ProxyServlet: /rapdemo/start) is not
available.
Apache Tomcat/5.5.20
LOG:
osgi>
ss
09:06:52,309 INFO [STDOUT] Framework is launched.
09:06:52,309 INFO [STDOUT] id
09:06:52,309 INFO [STDOUT] State Bundle
09:06:52,309 INFO [STDOUT] 0 ACTIVE
09:06:52,309 INFO [STDOUT] Fragments=
09:06:52,309 INFO [STDOUT] 28
09:06:52,309 INFO [STDOUT] 1 ACTIVE
09:06:52,309 INFO [STDOUT] 2 ACTIVE
09:06:52,309 INFO [STDOUT] 3 ACTIVE
09:06:52,309 INFO [STDOUT] 4 ACTIVE
09:06:52,309 INFO [STDOUT] 5 ACTIVE
09:06:52,309 INFO [STDOUT] 6 ACTIVE
09:06:52,309 INFO [STDOUT] 7 ACTIVE
09:06:52,309 INFO [STDOUT] 8 ACTIVE
09:06:52,309 INFO [STDOUT] 9 ACTIVE
09:06:52,309 INFO [STDOUT] 10 ACTIVE
09:06:52,309 INFO [STDOUT] 11 ACTIVE
09:06:52,309 INFO [STDOUT] 13 ACTIVE
09:06:52,309 INFO [STDOUT] 14 ACTIVE
09:06:52,309 INFO [STDOUT] 15 ACTIVE
09:06:52,309 INFO [STDOUT] 16 ACTIVE
09:06:52,309 INFO [STDOUT] 17 ACTIVE
09:06:52,309 INFO [STDOUT] 28 INSTALLED
09:06:52,309 INFO [STDOUT] 37 ACTIVE com.we4it.rap_1.0.1
09:06:52,309 INFO [STDOUT] 73 ACTIVE
org.eclipse.rap.ui_1.0.0.20071010-2241
09:06:52,309 INFO [STDOUT] 78 ACTIVE
org.eclipse.core.expressions_3.3.0.v20070606-0010
osgi>
Re: Problem during starting Bundle [message #61413 is a reply to message #61389] |
Wed, 21 November 2007 08:38 |
Member |
Try with http://localhost:8080/we4it/rap?startup=start
> Greetz
> type Status report
> available.
> LOG:
> osgi> ss
> 09:06:52,309 INFO [STDOUT] osgi>
Current Time: Wed Jul 03 01:21:01 GMT 2024
Powered by FUDForum. Page generated in 0.03583 seconds
